Kramer Masonry
Unread 03-01-2011, 08:32 PM   #1
Default Keep Your Release Bearing Alive With The Ram Clutch Pedal Adjuster
Fine-tune clutch pedal heights on aftermarket or OEM systems with the Ram Clutch Pedal Adjuster. It can help erase problems with over-travel of the release bearing, which can control it and cause high RPM engagement problems.
Keep Your Release Bearing Alive With The Ram Clutch Pedal Adjuster NewsBot Dragzine Newsfeed 0 03-01-2011 07:44 PM
