Unread 12-13-2010, 06:58 PM   #1
Default PRI 2010: T&D Machine Releases Ford FE Shaft Mount Rockers
These shaft mounts are T&D's direct replacement versions. These aluminum rockers feature a 1.76:1 ratio with a full roller bearing. They are designed for stock FE or Edelbrock counterparts. To further reduce rocker deflection, the end of the rocker shafts are captured.
PRI 2010: Ross Releases New Pistons For Ford 2-Valve TFS Heads NewsBot Dragzine Newsfeed 0 12-11-2010 05:19 PM
PRI 2010: Crower Expands Shaft Mount Rocker Line NewsBot Dragzine Newsfeed 0 12-11-2010 04:36 PM
Cross Between 1967 And 2010 Camaros Wins Goodguys Street Machine Award NewsBot Street Legal TV Newsfeed 0 08-11-2010 08:10 PM
TFS CNC 235cc Heads for LS2-LS3 and stroker LS engines w/shaft mount rockers Fryguy302 Classifieds 1 07-17-2010 12:54 AM
Ford Now Offering Over 9,000 Reproduction Car Parts NewsBot Street Legal TV Newsfeed 0 06-09-2010 05:32 PM
