Payso Productions
Unread 04-29-2005, 07:02 AM   #1
cobrafreak01
Do-it-yourself-er
cobrafreak01 I need rep points!
Default Cool Dragster Facts
1. One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500.
2. Under full throttle, a dragster engine consumes 1.5 gallons of nitromethane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
3. A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster supercharger.
4. With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
5. At the stoichiometric 1.7:1 air/fuel mixture for nitromethane the flame front temperature measures 7050 degrees F.
6. Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
7. Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
8. Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
9. If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
10. In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. In order to reach 200 mph well before half-track, the launch acceleration approaches 8G's.
11. Dragsters reach over 300 miles per hour before you have completed reading this sentence.
12. Top Fuel Engines turn approximately 540 revolutions from light to light!
13. Including the burnout the engine must only survive 900 revolutions under load.
14. The redline is actually quite high at 9500 rpm.
15. The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated US $1,000.00 per second. The current Top Fuel dragster elapsed time record is 4.44 1 seconds for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00 mph (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta)
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race course
cobrafreak01 is offline   Reply With Quote
Unread 04-29-2005, 07:34 AM   #2
99SVTAddict
99SVTAddict's Avatar
Right out of Motor Trend, Jan 05 Edition.
Unread 04-29-2005, 10:18 AM   #3
Nitro cars are the shit, if you havent seen one run up close you dont know what you missing. Couple additional facts or updates
A TopFuel Motor currently produces between 7000 and 8000 horsepower
It accelerates faster on launch than a fighter jet being catapulted off a Aircraft carrier
The driver pulls more intial G's than Astronauts aboard the Shuttle during launch
On a "typical" 4.5sec run, the fueler reaches 270mph by the 1/8 mile.
The rear wing can produce upwards of 4000lbs of downforce on the rear tires, thats like carrying a full size car on the back.
The negative G's that the drivers experience when the Parachute deploys can detach retinas
Current quickest runs are 4.421 seconds and 335+ mph. These are not the current official records because a record run must be backed up with in 1% at the same event that intial run was made.
Burning Nitromethane is the best sinus clearer in the world, I know this from personal experience. I now take a resperator/mask with me when I go to National events
New rules this year have mandated a rev limiter set at 8600rpm, and the cars are running as quick as before, but actually showing more MPH than last year.
And while TopFuelers are the quickest wheel driven vehicles on the planet, in the last 20 years, there have been only 2 fatalities for Drivers at NHRA sanctioned events. That is an impressive safety record.
Lastly, theyre racing this weekend, check ESPN2 for qualifying on Saturday nite, and eliminations on Sunday evening.
Unread 04-29-2005, 10:26 AM   #4
thats just crazy..
Unread 04-29-2005, 11:01 AM   #5
I love nitro cars
Unread 04-29-2005, 08:00 PM   #6
Cool facts. Nitor rocks!
