11-09-2010, 12:28 PM
Mopar/ race parts for sale, cleaing out the garage-Michigan
Misc Mopar Parts For sale:
1-new Dodge Ram lighted hitch cover $ 5.00
1-used Blown 426 Hemi blower cam $ 100.00
1-new 94-02 club cab body moulding $10.00
1- new P4120758 Mopar clutch fan for b.b. or Hemi $100.00-SOLD
2-new P4120074 3” dia. Leaf spring perches $ 20.00 / pr-SOLD
1-used Mopar Performance black wrinkle finish air cleaner for 4150 carb $ 50.00-SOLD
2- new/used std Mopar performance windage trays $ 20.00 ea.
1-new 4.150 stroker Mopar Performace windage tray $30.00
4-used Bullit style 68 Dodge hubcaps $25.00 ea.
1-used E-Body power Steering gear box $100.00
2-used E-Body leaf springs & shock plates $ 100.00
1-used 8-3/4 742 2:96 center section $100.00-SOLD
1-used Dana 60 3:54 center section & ring & pinion $ 150.00
1 used 4.0L Jeep auto trans yoke $ 40.00
1-used Mopar performance adj. pinion snubber $ 20.00
1-used E-body 727, 8-3/4 driveshaft $100.00
2-used steel crank dampers $ 40.00 ea.
1-used b.b. power steering pump $50.00
1-used 70 cast iron 4 bbl intake $ 40.00
1-used 70 B&E body oil pan $ 40.00
1-used 73-93 p.u. or Ramcharger b.b. trans cross member $40.00
1-used A Body 727 trans cross member $40.00
1-used B Body 727 trans cross member $40.00-SOLD
1-used set 452 b.b iron heads $100.00
1-used 3.750 70 440 steel forged crank $150.00
1-new 3.750 Eagle stroker 8 bolt flange HEMI forged steel crank $500.00
1-new 4.150 Eagle stroker 8 bolt flange HEMI forged steel crank $500.00-SOLD
2-used 70 Challanger front side marker lights $ 15.00 ea.
2-used b.b. motor mounts $20.00
1-used set od b.b. main cap & bolts $40.00
8-new P4120294 426 HEMI spark plug tubes $45.00 /set
1-used tach drive distributor $50.00
1-new P4529895 426 HEMI valve cover breather assembly $30.00-SOLD
1-new P3690936 cam offset bushing kit $20.00
2-new P4876926 HEMI spark plugs (4 plugs per pack) $15.00 ea.
1-new Hemi/b.b. many cam & plug dowel pin kits all mixed together $40.00
1-new P5249191 T-stat housing with gasket &t-stats $ 25.00-SOLD
15-new P4006767 b.b. / Hemi lifters $5.00 ea. $60.00 for all
1-new PD-17 Durabond b.b cam bearing kit $ 20.00
5-new 426 HEMI intake & exhaust rocker arms $ 65.00 ea. $300.00 for all-SOLD
8-new CB527HND Clevite std b.b. rod bearings $ 80.00 for all 8 pair-SOLD
1-new MS1277HG Clevite std b.b. main bearing set $ 75.00-SOLD
1-new P4529699 sfi approved b.b./hemi damper $250.00
1-used lot of misc cast iron exhaust manifolds, intakes, oil pans, alternators, starters etc.
1- Most brand new NOS in packages or slightly used (Dyno time only)
-5.7L Hemi fuel injection set ups(5)with throttle bodies, injectors, injector rails, spark plug wire assy's etc $250.00 ea. , Air cleaner box assy (6) $40.00 ea. , Flywheels (7) with hdwe $40.00 ea. , Bell housings (2) $100.00 ea., Complete engine bay wire harnesses (2) $100.00 ea. , idle pulley (5) 15.00 ea., tensioner pulley (5) $15.00 , Exhaust manifolds heat shields (6) $5.00 ea. Emissions tubes $5.00 ea. (2) many bags, boxes of NOS mounting hdwe, clips & fasteners etc.
http://photobucket.com/6PKRTSE1 for photo's of the new items.
call 1-313-505-7948 Make an offer on all items. I have no use for any of the items & need to make room.
