Unread 08-16-2010, 03:46 PM   #1
slow5.0
slow5.0 I need rep points!
Default pls help
i just put my motor together and went to fire it up but the pistons hit the plugs. what should i do any help would be greatly appreciated? the combo is as follows
performer heads
x-303
trw pop up pistons (306)sbf
stock leangth push rods
performer intake
750 holley dp
full msd ing.
plugs are 14mmx3/4 reach
thank you
slow5.0 is offline   Reply With Quote
Unread 08-16-2010, 05:13 PM   #2
I bet those are the wrong plugs. Call Edelbrock and verify it.
Unread 08-16-2010, 10:34 PM   #3
Bluefox91
11.02 @123
Bluefox91's Avatar
Bluefox91 I need rep points!
try 3924's i just sold a set the other day and they worked out fine with no issues
10 speed/2 kits/2 inch wide slick/carbon fiber pedals
squeaky horn
Bluefox91 is offline   Reply With Quote
Unread 08-17-2010, 03:06 PM   #4
x2
Unread 08-17-2010, 05:36 PM   #5
slow5.0
thanks for the help guys
Unread 08-17-2010, 07:12 PM   #6
Wrong plugs?
Unread 08-17-2010, 09:21 PM   #7
1BADAIR
FLOORMAT RACING
1BADAIR's Avatar
1BADAIR I need rep points!
3/4 is correct
http://www.edelbrock.com/automotive_...6000/60399.pdf
1BADAIR is offline   Reply With Quote
Unread 10-25-2010, 09:12 PM   #8
What do the pistons look like? Dome shape?
Unread 11-08-2010, 11:12 AM   #9
Foolsgold80z
Foolsgold80z's Avatar
Foolsgold80z I need rep points!
You may have to use washers and index the plugs also.
Foolsgold80z is offline   Reply With Quote
