Unread 07-18-2010, 08:40 AM   #1
565bbccarbed
565bbccarbed's Avatar
565bbccarbed I need rep points!
Default 69 nova ss chassis car roller /bbc
I have this well built tube chassis 69 nova ss that is been our race car (certified in 2001 8.50 sportsmen 3 NHRA ) , everything gone threw this past spring .We did some testing with a 565 bbc /th400 transbrake dialing in the suspension and ended up with motor problem . Best times were 9.80's @ 137 mph with a 138 60 foot coming off the transbrake at 5200 rpm .Now selling the car as a roller / ready for you to drop your motor + trans combo in and race . --- The car has been dropped 8" and motor moved back 14" from stock location fits awesome , car is freshly painted inside and out , underside of car is painted white , the body is steal with fiberglass decklid , fiberglass bumbers ,fiberglass cowl hood with snorkle mounted on , and lexan threw out , front tires m/t sportsmen 28" on drag centerline rims -rear tires m/t slicks 31 X 13.5 on drag centerline rims
The car has a 12 bolt (40 spline axles -spool) ,4:33 gear, ladder barred double coil over suspension mark williams chromemoly driveshaft ,mw billit yoke , mw pinion billit yoke ,front and rear driveshaft loops . The tube chassis ties in at the modified front sub frame with rack and pinion steering and disk brakes .The car has a line lock on shifter , transbrake button on steering wheel , 3 speed shifter reverse pattern ,trans cooler in passenger side fenderwell with fan , 31" aluminum radiator with 2 electric fans + hoses, mid plate and front motor plate for bbc ,chassis car style headers 2 1/4" w 4" collector bbc , fuel system complete 5 gallon cell -12 an outlet -10 on return from mallory 5 port regulator w boost reference too ,all 5/8 " aluminum line with a aeromotive 11104 eliminator pump + filter , -8 lines to carb fuel guage in car from isolator, complete electrical duel 1000 amp new batteries (car set up for alternator too) kill switch , guages inside , monster tach with shift light , control panel mounted on custom box , MSD digital 6 box , blaster 3 coil , fuse panel ,one brake light +side marker ,new window net , new 5 point belt ,disconnect momo wheel ,CSR flywheel shield #835, used trans blanket , parachute mount-lever and cable - no parachute , wheelie bar mounts on axle -no wheelie bars . Lets talk about the sale $14,500 obo as roller ready for your motor and trans -Trades possible with cash my way unless worth full amount interest in 70 chevelle street strip ext.cab 4x4 or 4 door 98 pick up or newer clean please contact interest car is located in Oxford Michigan Thank you !
565bbccarbed is offline   Reply With Quote
Unread 07-18-2010, 07:21 PM   #2
565bbccarbed
It also has a new kirkey seat and cover too.
Unread 08-10-2010, 07:44 PM   #3
565bbccarbed
I have to lower the price to sell please inquire , now sell for $ 8,200.00 - no trades please .
Unread 09-19-2010, 04:37 PM   #4
565bbccarbed
I now have a lower price LOOK -- $ 5500 still as complete as listed above ! text or contact 248 701 57 one six .Thank you
Unread 09-26-2010, 11:12 AM   #5
565bbccarbed
Car is sold .Thanks to Ryan and Bill from IOWA .
Craiglist Find: Immaculate 10-Second Chevy II Nova SS NewsBot Street Legal TV Newsfeed 0 06-28-2010 04:36 PM
MaxStreet Nova II - Second Update - Mini Tubs and Wheel Fitment NewsBot Street Legal TV Newsfeed 0 06-14-2010 04:44 PM
MaxStreet 1966 Nova II - Fabrication Project First Update - Big Block NewsBot Street Legal TV Newsfeed 0 06-07-2010 09:09 AM
Hyd. Roller Turbo camshaft and brand new tie-bar style hyd. roller lifter for SBF Fryguy302 Classifieds 1 06-21-2007 08:39 AM
GM Chassis Service Manuals Strtracer Classifieds 1 04-07-2005 01:07 AM
