Unread 07-07-2010, 10:53 AM   #1
Default ProCharger Announces New Stage II Intercooled Supercharger Systems for 2010 Camaro SS
ProCharger has just released an intercooled stage II system and a tuner kit for the 2010 Camaro SS. The new kit includes a larger 1,300 HP air-to-air intercooler and a new low restriction air inlet with a larger air filter.
Official Release:
Realizing the performance potential of modified LS-engines, ProCharger is once again leading the way with the release of both an Intercooled Stage II System and Tuner Kit for the 2010 Chevrolet Camaro SS. When compared with the industry-leading HO System and Tuner Kit, the new Stage II offering includes a larger, 1,300 HP front-mounted air-to-air intercooler, along with a new, low restriction air inlet and larger air filter.
The new Stage II System is 100 percent complete with a P-1SC-1 ProCharger and includes injectors, computer programmer and utilizes an 8-rib, dedicated drive and tensioner system, with a 12-rib dedicated drive available as an upgrade on Tuner Kits. The heavy-duty bracket provides a solid, stable mounting location for a wide range of ProCharger models, including the standard P-1SC-1. The larger ProCharger D-1SC, F-1D/F-1/F-1A or F-1C/F-1R supercharger models are only available in the Tuner Kit.
Stage II Tuner Kits
Designed specifically for 2010 Camaro SS owners who are planning future engine modifications, the Stage II Intercooled Tuner Kit is identical to the complete system, but comes without fuel injectors and the hand-held ECU programmer. Higher boost and power levels are available via the Stage II Tuner Kit for modified engines.
Stage II System and Tuner Kit Retail Pricing:
Stage II Intercooled System (P-1SC-1 supercharger) MSRP: $7,510
Stage II Intercooled Tuner Kit (P-1SC-1 supercharger) MSRP: $6,810
Stage II System and Tuner Kit Options/Upgrades:
ProCharger D-1SC Supercharger (Tuner Kits only)
Helical Gearset for Noise Reduction (P-1SC-1 and D-1SC superchargers only)
12-Rib Supercharger Drive Upgrade
ProCharger F-1D / F-1 / F-1A Supercharger Upgrade (Tuner Kits only)
ProCharger F-1C / F-1R Supercharger Upgrade (Tuner Kits only)
Availability:
Both the Stage II System and Tuner Kit are available now. Contact your local ProCharger dealer or call ProCharger at 913/338-2886 for the name of your nearest ProCharger dealer.
With the release of the new Stage II Intercooled System and Tuner Kit, ProCharger has extended their leadership position in air-to-air intercooled centrifugal supercharger solutions for the very popular 2010 Camaro SS.
HO Intercooled System
HO Intercooled Tuner Kit
NEW Stage II Intercooled System
NEW Stage II Intercooled Tuner Kit
Cog Race Kit
ProCharger 2010 Camaro SS notes:
ProCharger intercooled supercharger systems and tuner kits are designed to install onto stock LS3 and L99 engines used in the 2010 Camaro SS
Complete ProCharger Systems (HO and Stage II) now include a hand-held computer programmer to install the ProCharger-developed tune.
The first 2010 Camaro SS to run in the 9’s did so using a ProCharger F-1R supercharger (9.98 @ 144 mph back in December 2009)
  • Designed specifically for 2010 Camaro SS owners who are planning future engine modifications
  • Stage II System is 100 percent complete with a P-1SC-1 ProCharger
  • designed to install onto stock LS3 and L99 engines
Contact Information:
ProCharger
Web: www.procharger.com
Phone: 913-338-2886
The New Camaro - an email from Scott Settlemire Joe The Alley 6 08-15-2006 08:53 AM
