Unread 01-31-2010, 12:13 PM   #1
leos69z28rs
leos69z28rs I need rep points!
Default Fabrication needed, must have surface plate.
1969 CAMARO Z28 RS DZ “F” BODY COUPE
It will be an Upgraded 69 Z28 Muscle Street Car.
When I bought the car in 1976 100% original, who ever repaired the rear hit, hack it up and did not replace the kinked rear frame rails which are not available now.
1. I will supply sub frame, pair of 69 Camaro OEM shaped “PROFILE RAILS” 2X3X11ga box steel rails from autoweldchassis.com and the Print with all Dimensions.
2. Build on a holding fixture and off rear OEM sub frame (no body) and add the “PROFILE RAILS” (mid and rear frame section) to OEM Horizontal & Vertical Dimensions.
3. I will also compensate for any addition or material provided.
Email leolhaudek@comcast.net your estimated quote, how long to build after you received all the parts, your phone number and address so we can meet in person.
If you can do this, or recommend someone that can, Funds are waiting.
Thanks,
Leo L. Haudek
Warren, Michigan.
leos69z28rs is offline   Reply With Quote
Unread 01-31-2010, 09:02 PM   #2
Contact Todd Reiter at ReitersMetal craft.
PacecarBBC on here. He is also a sponsor.
Unread 01-31-2010, 10:05 PM   #3
leos69z28rs
Thank's, Todd place is top notch.. Todd wanted the car to build from.
I have a body panel man that has a good plan to install one part (fab frame), instead of building many parts into old body. When the old body is supported, slice all the floor panels to fit the new fab frame then tie everthing needed to hold it in its place. Then replace one panel at a time, from the bottom up. Time is Money...
Need someone to build new mid-back section off sub-frame to OEM specs.
Current projects at Diamond Fabrication Diamond Sponsors 23 11-02-2010 01:53 PM
needed: used headliner needed for my Challenger 6PKRTSE Classifieds 0 01-27-2010 12:55 PM
Custom Plate Ideas 99TransAmWs6 The Alley 12 02-15-2007 08:49 PM
