Unread 03-13-2009, 05:45 PM   #1
jsalvato1
jsalvato1's Avatar
jsalvato1 I need rep points!
Default FS: Brand New SBF Mahle piston & ring kits
I have a variety of Mahle Piston & Rings Kits for sale for a SBF. They are all new in the box. Let me know what part number you are interested in and I'll get you a price.
Email me at jsalvato1@aol.com
SBF090000F06 4 x 3.400 5.400Rod .927Pin 1.090RComp Height -6.6cc Valve Relief Volume 388g 9.95 CR
SBF090030D07 4.030 Bore .927Pin 1.090RComp Height 7cc Dome 446g 11.9 CR
SBF090030F00 4.030 x 3.400 5.400Rod .927Pin 1.090RComp Height 0cc Valve Relief Volume 413g 10.8 CR
SBF090030F06 4.030 x 3.400 5.400Rod .927Pin 1.090RComp Height -6.6cc Valve Relief Volume 395g 9.95 CR
SBF090030I16 4.030 x 3.400 5.400Rod .927Pin 1.090RComp Height -16cc Dish 385g 9.0 CR
SBF090040F00 4.040 x 3.400 5.400Rod .927Pin 1.090RComp Height 0cc Valve Relief Volume 416g 10.8 CR
SBF090040F06 4.040 x 3.400 5.400Rod .927Pin 1.090RComp Height -6.6cc Valve Relief Volume 398g 9.95 CR
SBF090040I16 4.040 x 3.400 5.400Rod .927Pin 1.090RComp Height -16cc Dish Volume 388g 9.0 CR
SBF090060F00 4.060 x 3.400 5.400Rod .927Pin 1.090RComp Height 0cc Valve Relief Volume 421g 10.8 CR
SBF090060I16 4.060 x 3.400 5.400Rod .927Pin 1.090RComp Height -16ccDish Volume 392g 9.0 CR
SBF090125F06 4.125 x 3.400 5.400Rod .927Pin 1.090RComp Height -6.6cc Valve Relief Volume 446g 9.1 CR
SBF090125I16 4.125 Bore .927Pin 1.090RComp Height -16cc Dish Volume 414g 8.0 CR
SBF165000F06 4 x 3.250 5.400Rod .927Pin 1.165Comp Height -6.6cc Valve Relief Volume 405g 9.55 CR
SBF165000I16 4 x 3.250 5.400Rod .927Pin 1.165Comp Height -16cc Dish Volume 395g 8.7 CR
SBF165030D07 4.030 Bore .927Pin 1.165Comp Height 7cc Dome 466g 11.4 CR
SBF165030F00 4.030 x 3.250 5.400Rod .927Pin 1.165Comp Height 0cc Valve Relief Volume 427g 10.4 CR
SBF165030F06 4.030 x 3.250 5.400Rod .927Pin 1.165Comp Height -6.6cc Valve Relief Volume 412g 9.55 CR
SBF165030I16 4.030 x 3.250 5.400Rod .927Pin 1.165Comp Height -16cc Dish Volume 402g 8.7 CR
SBF165040F00 4.040 x 3.250 5.400Rod .927Pin 1.165Comp Height 0cc Valve Relief Volume 431g 10.4 CR
SBF165040F06 4.040 x 3.250 5.400Rod .927Pin 1.165Comp Height -6.6cc Valve Relief Volume 416g 9.55 CR
SBF165040I16 4.040 x 3.250 5.400Rod .927Pin 1.165Comp Height -16cc Dish Volume 406g 8.7 CR
SBF165060F00 4.060 x 3.250 5.400Rod .927Pin 1.165Comp Height 0cc Valve Relief Volume 437g 10.4 CR
SBF165060F06 4.060 x 3.250 5.400Rod .927Pin 1.165Comp Height -6.6cc Valve Relief Volume 423g 9.55 CR
SBF165060I16 4.060 x 3.250 5.400Rod .927Pin 1.165Comp Height -16cc Dish Volume 410g 8.7 CR
SBF165125F06 4.125 x 3.250 5.400Rod .927Pin 1.165Comp Height -6.6cc Valve Relief Volume 456g 8.7 CR
SBF245000F06 4 x 3.500 6.200Rod .927Pin 1.245Comp Height -6.6cc Valve Relief Volume 414g 10.2 CR
SBF245030F00 4.030 x 3.500 6.200Rod .927Pin 1.245Comp Height 0cc Valve Relief Volume 439g 11.0 CR
SBF245030F06 4.030 x 3.500 6.200Rod .927Pin 1.245Comp Height -6.6cc Valve Relief Volume 421g 10.2 CR
SBF245030I20 4.030 Bore .927Pin 1.245Comp Height -20cc Dish Volume 389g 10.0 CR
SBF245030I26 4.030 x 3.500 6.200Rod .927Pin 1.245Comp Height -26cc Dish Volume 388g 8.4 CR
SBF245040F00 4.040 x 3.500 6.200Rod .927Pin 1.245Comp Height 0cc Valve Relief Volume 442g 11.0 CR
SBF245040F06 4.040 x 3.500 6.200Rod .927Pin 1.245Comp Height -6.6cc Valve Relief Volume 424g 10.2 CR
SBF245040I26 4.040 x 3.500 6.200Rod .927Pin 1.245Comp Height -26cc Dish Volume 392g 8.4 CR
SBF245060F00 4.060 x 3.500 6.200Rod .927Pin 1.245Comp Height 0cc Valve Relief Volume 447g 11.0 CR
SBF245060F06 4.060 x 3.500 6.200Rod .927Pin 1.245Comp Height -6.6cc Valve Relief Volume 429g 10.2 CR
SBF245125D07 4.125 Bore, 4.100 Strk, 6.200 Rod, 0.927 Pin, 1.245 C/H, 7cc Vol, 485 g, 438.3 C.I., 16.0 C/R
SBF245125F06 4.125 x 3.500 6.200Rod .927Pin 1.245Comp Height -6.6cc Valve Relief Volume 466g 9.3 CR
SBF245125I26 4.125 x 3.500 6.200Rod .927Pin 1.245Comp Height -26cc DDishf Volume 420g 7.6 CR
SBF245155F06 4.155 Bore .927Pin 1.245Comp Height -6.6cc Valve Relief Volume 469g 9.3 CR
SBF245155I26 4.155 Bore .927Pin 1.245Comp Height -26cc Dish Volume 430g 7.6 CR
SBF300030F06 4.030 Bore .927Pin 1.300Comp Height -6cc Valve Relief Volume 418g 9.0CR
SBF300030I20 4.030 Bore .927Pin 1.300Comp Height -20cc Dish Volume 396g 7.8 CR
SBF600000I26 4 x 3.850 5.956Rod .912Pin 1.600Comp Height -26cc Dish Volume 425g 9.2 CR
SBF600030F00 4.030 x 3.850 5.956Rod .912Pin 1.600Comp Height 0cc Valve Relief Volume 482g 12.0 CR
SBF600030F06 4.030 x 3 5.090Rod .912Pin 1.600Comp Height -6.6cc Valve Relief Volume 464g 9.0 CR
SBF600030I26 4.030 x 3.850 5.956Rod .912Pin 1.600Comp Height -26cc Dish Volume 432g 9.2 CR
SBF600040F00 4.040 x 3.850 5.956Rod .912Pin 1.600Comp Height 0cc Valve Relief Volume 486g 12.0 CR
SBF600040F06 4.040 x 3 5.090Rod .912Pin 1.600Comp Height -6.6cc Valve Relief Volume 468g 9.0 CR
SBF600040I26 4.040 x 3.850 5.956Rod .912Pin 1.600Comp Height -26ccDish Volume 436g 9.2 CR
SBF600060F00 4.060 x 3.850 5.956Rod .912Pin 1.600Comp Height 0cc Valve Relief Volume 492g 12.0 CR
SBF600060F06 4.060 x 3 5.090Rod .912Pin 1.600Comp Height -6.6cc Valve Relief Volume 476g 9.0 CR
SBF600060I26 4.060 x 3.850 5.956Rod .912Pin 1.600Comp Height -26cc Dish Volume 453g 9.2 CR
SBF775030F00 4.030 Bore .927Pin 1.775Comp Height 6cc Valve Relief Volume 477g 10.3CR
jsalvato1 is offline   Reply With Quote
