Unread 01-24-2009, 05:17 PM   #1
351nxtlane
351nxtlane I need rep points!
Default What coil over spring
What the best length spring and weight to use with a windsor in a notch. Driven more on the street but i really want it to leave hard at the track. Thanks.
351nxtlane is offline   Reply With Quote
Unread 01-24-2009, 06:10 PM   #2
Boomer!
Infraction Jackson !!!!!!
Boomer!'s Avatar
Boomer! I need rep points!
Strange, AFCO and Qa1 stuff all work good. A double adjustable strut or shock is going to be your best buy as it gives you a wide array of set ups. Spring rate really should be determined by weight, have the front of the car weighed and the rear and get the correct spring rate. Length will depend on the brand and open/compressed height of shock/strut.
Boomer! is offline   Reply With Quote
Unread 01-26-2009, 08:24 PM   #3
pacecarBBC
pacecarBBC's Avatar
pacecarBBC I need rep points!
i have been using the 14" spring with a 130lb rate and have ad great results, and always strange struts if that helps.
Reiter's Metal Craft
www.reitersmetalcraft.com
pacecarBBC is offline   Reply With Quote
Unread 01-26-2009, 08:31 PM   #4
Pwraddr
Pwraddr I need rep points!
Todd, this is with a SBC in the Wife's car? SN95?? Just curious
1989 Mustang Coupe
1992 Mustang Coupe
Windsor/C4
Pwraddr is offline   Reply With Quote
Unread 01-26-2009, 10:10 PM   #5
Boomer!
Boomer!'s Avatar
I had 14" 130's on my 96 turd, I had to really crank the adjustment up to keep it from the low rider stance until I bought 170's. I am wondering if the spring manufacturer had something to do with it ?????
Unread 01-28-2009, 11:29 PM   #6
351nxtlane
From what I've investigated 130 to 150 is for all out track only. It seams 175 is the sweet spot for driving on street and works at the track. I already have Lakewood 90/10 for the frt. Any input for the rear set up ?
Unread 04-04-2009, 10:56 PM   #7
billydroveit
billydroveit I need rep points!
14/175 front, stock 4 banger springs cut to length for the rears.
billydroveit is offline   Reply With Quote
Unread 05-09-2010, 09:33 AM   #8
meatbag
meatbag I need rep points!
Is anybody running a rear coilover and if so what spring rate worked for you iam running strange adjustables and have a coilover but iam not using it cause the springs that came with it wont hold the car up its street driven as well.
meatbag is offline   Reply With Quote
Unread 04-07-2017, 01:33 AM   #9
michael06
michael06 I need rep points!
Stock springs work best for the rear. You can get stock 5.0 springs and trim them to get the ideal stance you are looking for. I have bilstein with 14/175 on the front and rear stock springs.
michael06 is offline   Reply With Quote
Unread 09-16-2018, 08:22 AM   #10
Gtmustang
Gtmustang I need rep points!
I use a 115# rate rear coil spring for street/strip use in a 1992 GT Mustang, no problems. In the front I have 175# 14" coilover springs. Drag race only, I'd use 150#.
Gtmustang is offline   Reply With Quote
modern traction bars part 1 Lunger Technical Articles and "How To's" 7 07-21-2011 11:07 AM
SKRC coil over mt kit for mustang rear bodeanracing Classifieds 1 08-26-2008 10:55 AM
Baer Brake Installed venom88 Technical Articles and "How To's" 2 06-01-2005 07:00 AM
Spring event question 99SVTAddict The Alley 14 04-13-2005 10:48 AM
my project reborn silverknight The Alley 33 04-05-2005 08:11 PM
