Unread 12-06-2008, 11:23 PM   #1
tnum01
i wanna go fast
tnum01's Avatar
tnum01 I need rep points!
Default 88 mustang gt tech question
i want to convert efi to carb on my 88 mustang gt.what is all involved and what do i need to change???someone told me i need to get a whole nother block but i dont buy that.any info would be great
tnum01 is offline   Reply With Quote
Unread 12-07-2008, 06:59 AM   #2
All you need to do is change the intake and add the carb. There is some minor wiring involved, obviously, because you have to change to a duraspark box or other ignition. Also, you will need to either regulate the fuel pressure down, or install a lower pressure electric fuel pump. The carb will need much less fuel pressure. The throttle cable will need to be changed or modified also.
Unread 12-07-2008, 09:57 AM   #3
tnum01
i wanna go fast
tnum01's Avatar
thank you
Unread 12-07-2008, 03:14 PM   #4
I believe you may need a different throttle cable. I know the early Mustangs (79-85) have a different cable than te efi cars.
Unread 12-08-2008, 11:59 AM   #5
hangem high
hangem high I need rep points!
You can run the efi ecm with the carb. Did it many times.. But the correct way is to install msd or what ever ignition you like. If you change to a lower pressure pump you need to remove the pump in the tank also.
hangem high is offline   Reply With Quote
1967 Mustang fastback(390) and 1969 mustang fastback projects $5500 DarkoStoj Classifieds 0 10-20-2007 03:17 PM
Help, Help 4.6L Mustang SVT32VDOHC The Alley 1 07-20-2007 05:01 PM
You still have a chance for a Speed Pink’s: All Out Race Entry Joe Events 0 04-19-2007 12:47 PM
89 Mustang 5.0 Question cobrafreak01 The Shop 3 08-19-2005 04:51 PM
ITT TECH silverknight The Alley 4 04-24-2005 10:02 AM
