Go Back   Detroit Racing Forums > General Discussion > The Gym
Unread 03-08-2008, 08:21 AM   #1
90-notch
90-notch I need rep points!
Default What should I lift?
I've been wondering what would be a safe calculation for me to figure out what i should lift for MAX growth of the muscle.
Lately i just hit my higest ever lifted on inclines in a long time of 135lbs (3x10). I know it's sad that i can curl more than i can incline bench but i'm happy that i finally hit a plate.
Now is there away to calculate what i should lift for a workout? I can do the 3x10 pretty easy up until the last set at about 8 on that set my spotter has to jump in.
I was doing a 1x's max calculator and my max lift is 180lbs. Altho it's probably higher because that's only calculatated on 1 set.
Here's the break down of the 1x's max lift calculator
Weight lifted= 135
Reps=10
50% 1RM=90lbs
55% 1RM=99lbs
60% 1RM=108lbs
65% 1RM=117lbs
70% 1RM=126lbs
75% 1RM=135lbs
80% 1RM=144lbs
85% 1RM=153lbs
90% 1RM=162lbs
95% 1RM=171lbs
Where on this chart should i lift for the MAX muscle/strength growth?
90-notch is offline   Reply With Quote
Unread 03-25-2008, 07:40 AM   #2
LITTLEMAGS
LITTLEMAGS's Avatar
LITTLEMAGS I need rep points!
i wouldnt use the incline as a set point for max growth. USE a compound movements where the body is more stablized. I gotta find the article but 1 rep range doesnt envoke enough muscle tissue to stimulate muscle fibers. I wouldnt go less than 4 reps if growth is your may concern.
2004 mach 1..
stroked 4.6 F1a cog
735rwhp/585 tq for now....
LITTLEMAGS is offline   Reply With Quote
Unread 06-06-2008, 08:13 PM   #3
nitrous_bob
nitrous_bob's Avatar
nitrous_bob I need rep points!
imo, whatever it takes to do minimum of 3 but no more than 5 per set for a total of 30 , that way your lifting as heavy as possible for the entire workout
more important than the weight is your protein intake and the rest of your diet
'93 Calypso Notch , under construction...
6th stang and counting
nitrous_bob is offline   Reply With Quote
Cam Lift Question 357windsor The Shop 9 12-15-2008 12:53 PM
phase 6 chevy heads dozer Classifieds 0 12-09-2006 02:03 AM
90 F-150 Solid Dana 44 Swap new Eng 12" total lift! NICE CHEAP! thunderace31 Classifieds 20 11-20-2006 11:32 AM
Houston,,,, We have lift off!!! new pb 9.33 @ 148.01 Scott_DriveLineSolutions The Alley 9 09-25-2005 06:35 PM
WTB, Lower control arm's or Lift bar's, foxbody stang Casper302 Classifieds 3 01-09-2005 03:28 PM
