Unread 03-10-2005, 10:41 PM   #1
slowfive0
slowfive0
slowfive0's Avatar
slowfive0 I need rep points!
Default Butt load of Parts for Sale---Detroit area
Lots of Exhaust Parts!!!
Mac 1 5/8” Long Tube Headers for 79-93 Mustangs with Automatic
Headers have less then 500 miles on them---$150.00
2 ˝” Off Road H-pipe for shorty headers - 79-93---$50
2 ˝” Mac Cat Back with Chrome Tips - 94-98---$100---SOLD
Good shape with some surface rust on tips
Tons of Suspension Parts!!!
Off of my ‘93 notchback:
Steeda - Double Adjustable Upper Control arms (Urethane Bushings)---$125
These are in like new condition – less then 500 miles on them
Pro Launch 1 - Upper Control Arm Kit---BRAND NEW!!! Never even bolted on!!!
These kits are 260 new-------My price is $225
http://www.baselinesuspensions.com/
Saleen Lower control arms with urethane bushings---$75
Jegster Traction Bars/Rear Upper Control Arm Mounts for Mustang---$75
http://www.jegs.com/cgi-bin/ncommerc...48&prmenbr=361
Lower Control Arm relocation brackets (does same thing that Mega bytes & Southsides do). Bolts to rearend housing and relocates lower control arm for better suspension geometry (hits tires harder for improved launch)---$25---SOLD
Air bag (for right rear coil spring---for improved launch)---$20---SOLD
Moroso Trick front springs (1 coil cut off for better stance) - 94 & up---$50
Lakewood 90/10 Front Struts - 94 & up---$75---SOLD
Lots of Drivetrain Parts!!!
Built AOD-e, PI Lockup Torque Converter and Baumann TCS computer controller Combo --- 9 Second Capable & Fully streetable!!! Everything you need to perform upgrade----$1700
· Windsor based motors only---no Modular based motors
· Trans is fully upgraded---extra clutches, input stubshaft, output shaft, and mechanical diode
· Baumman stage 5 shift kit
· Baumman TCS---(Transmission Control System)
- http://www.baumannengineering.com/elect.htm
· Wiring harnesses to connect to transmission, laptop & engine harness
· Software
· Precision Industries “Triple Disc” lockup Converter (8 second capable converter!)
- $1100 dollar converter!
- 4500 stall in car going 11.0’s at 129 mph
- http://www.converter.com/stallion.htm
· Dipstick tube
· Stock shifter and shifter cable
· Modified transmission cross member
Moser 28 spline c-clip axles---$150
Repacked Traction Lock-28 spline---works awesome!---$75
TCI SFI approved 164 tooth - “0”/Internal balanced flexplate---$75
It has less then 30 miles on it!!!!
Selling Fuel and Electronic parts!!!
ATI Pro Pump (Same as T-rex, but better!)---$150
Comes with:
· Fuel lines to allow factory “plug in” installation
· Relay and wiring
· Bracket
· Insulation around pump so that you can’t hear it inside vehicle (Works Sweet!!!)
Mallory Fuel Tank Pickup Tube---$50
See link (page 20)
http://go.mrgasket.com/pdf/mal_fuel.pdf
Stock Fuel Tank (no rust or damage)---Make Offer
MSD Universal Boost Timing Master---$125
#5462---This unit can remove up to 20^ of timing. The basic BTM will only remove 15^.
Pro-M 83 mm MAF – 72lb calibration---$250
This isn’t the cheap plastic meter…
A3M Computer, Engine Harness & O2 Harness - Excellent Shape!!!---$200---SOLD
This is out of my ’93 – 5 spd car
MISC:
Autometer 2 5/8” Sport Comp-Boost/Vacuum Gauge (Black Face-Silver Bezel)---$25---SOLD
ASP 7” / 10 Rib Crank Blower Pulley (Steel)---$50
Has minor nicks that will easily clean up with a file
4 Valve-Cobra Underdrive pulley set (Crank and Water Pump)---$50
Ford Motorsport Smog Pump Eliminator---$50
Front & Rear Seats - Black---PERFECT Condition! Deluxe Interior---$400 for set
’93 Steering Column (Black) with Air bag, Ignition, etc---Perfect condition---$125
Air Bag Sensors for ’93 mustang---Make Offer
’93 Mustang HVAC Module Assembly (Heater Core/AC Evaporator, controls)---Perfect condition---Make Offer
slowfive0 is offline   Reply With Quote
Unread 03-10-2005, 10:49 PM   #2
Welcome to the site, please introduce yourself in the Alley and stick around.
