Carbon Fiber vented hood for 99-04 stangs
Weighs only 15 pounds, has steel renforced latching area, carbon fiber with gel clear coat. Has two reverse induction vents that sit right above the radiator and actually vent alot of the engine compartment heat. The hood has imperfections but will bolt on and look good. It doesn't show up in the pic, but there are a few light scratches in the center back half of the hood and some pin hole like imperfections int he front area from the gel coat, either way would be any easy paint or put on as is.
I picked this up locally, but ended up buying a Camaro instead of a Mustang.
Local pick up only, $300.
