Unread 09-04-2007, 11:26 PM   #1
mattitude74
Go fast....or go home!
mattitude74's Avatar
mattitude74 I need rep points!
Confused Suspenion question...
Mild to bad wheel hop, on a lightning....What would be good to resolve this issue? 4-link, traction bars? Any other options? Thanks for any help.
mattitude74 is offline   Reply With Quote
Unread 09-05-2007, 07:40 AM   #2
ToolBox
Made in Detroit!
ToolBox's Avatar
ToolBox I need rep points!
Traction bars from Lightning Force Performance or Cal-Tracs would be the way to go. Is you Lightning a gen1 or 2?
ToolBox is offline   Reply With Quote
Unread 09-05-2007, 07:43 AM   #3
ToolBox
Made in Detroit!
ToolBox's Avatar
Try this, It’s a great source of info for Lightning owners.
http://www.nloc.net/
Unread 09-05-2007, 07:55 AM   #4
I've never tried them, but I've heard those cal-tracs work great.
Unread 09-05-2007, 08:40 PM   #5
blk00rt
blk00rt's Avatar
blk00rt I need rep points!
Depends on if you are talking street or track.
Street just do not leave so high on the boost.
Track here is what I found works the best caltracs or competition engineering slide a links. You might want to also change your shocks to QA1's. They are 12 way adjustable and can help with weight transfer. Also disconnect your front sway bars if you have them. These are all tricks that I use on my truck though I have a nitrous dakota and not a supercharged lighting but I pull 1.6's all the time for 60 footers
Dunn
Rob Dunn
2000 Dakota RT
12.2 @ 105 mph
blk00rt is offline   Reply With Quote
Unread 09-09-2007, 02:01 AM   #6
mattitude74
It's a Gen 2. This is only going to be a street truck. The thing is I'm trying not to hurt ride quality, but help with it too. The truck sits at stock height. I run an extra 5-6 psi over stock. Heard the slide a link is more for strip though. I'll check out those Cal Tracs. Thanks all.
I have a question Xx96GTxX The Alley 16 04-07-2006 03:27 PM
Being asked the question? Steve Starnes The Alley 19 11-14-2005 09:59 AM
Question on where to buy a new brake light bulb 99SVTAddict The Alley 4 09-29-2005 01:07 PM
Trans Question cobrafreak01 The Shop 5 09-07-2005 03:45 PM
