Unread 07-26-2007, 08:58 AM   #1
Question Repairing plastic, need suggestions ASAP!!
Ok, I need your recommendation on something ASAP! I have a problem with my pool filter...it cracked and sprung a leak. Here is a pitcure of the filter tank...
If you look at the top of the tank itself you will kinda see where the two halves are fused together by the factory. At the very top is where it cracked and it has sprung a BAD leak. I need some kind of glue/adhesive that will be able to stand some pressure, not separate when the pump is turned on, and is also waterproof.
I ahve already tried epoxy (that cracked and seperated after a couple days), syringe epoxy (same result), and a couple other products All the same turnout.
I almost need something that will almost refuse/melt the pieces back together and hold them there...if their is such a thing.
Suggestions? This needs to be fixed today after I get off work.
Unread 07-26-2007, 09:05 AM   #2
99TransAmWs6
Hmmmm...
99TransAmWs6's Avatar
99TransAmWs6 I need rep points!
blow torch
-Cory
1999 Trans Am WS6
Street racing to some people equals 10% racing....90% trash talking.
99TransAmWs6 is offline   Reply With Quote
Unread 07-26-2007, 09:11 AM   #3
Originally Posted by 99TransAmWs6
blow torch
I actually tried that. I shit you not. It didn't work. I just started to melt the surrounding area including the large threads at the top of the tank that the regulator screws to. I had to keep screwing it on to make sure the threads stayed formed.
Unread 07-26-2007, 09:15 AM   #4
How about melting some more plastic on it (maybe an old toy or something) to fuse the two pieces together?
Unread 07-26-2007, 09:20 AM   #5
I would just buy a new one. Even if you get it sorta fixed, it wont last.
Unread 07-26-2007, 09:39 AM   #6
That tank is now obsolete. I called nearly 40 places and got the same answer. If I replace the tank, I need to replace the pump, base, regulator, etc. Damn all that.
Unread 07-26-2007, 09:41 AM   #7
Not a terrible idea, but I'm guessing I'd need to really score the inside of the crack that I would be filling...that would require me to crack it more than its already cracked. I'm not sure I'm willing to do that.
Unread 07-26-2007, 10:29 AM   #8
Krazybones
DEEEZ NUUUTZ
Krazybones's Avatar
Krazybones I need rep points!
Al my Tank cracked too before and I was able to buy just the top piece I needed and not the entire tank. It is a doughboy brand though. and why would you have to buy all (tank, pump, etc....) go buy a different brand as a Tank only and be done with it!
Krazybones is offline   Reply With Quote
Unread 07-26-2007, 10:32 AM   #9
The regulator on top is made for that tank alone and it spins on. Most CLAMP on today.
Tank is specially made to fit on this base.
The pump is also specially made to mount to this base.
Everything needs to be replaced if I replace the tank. Trust me, I have looked into it. I have been dealing with this fucked up tank on and off for the entire summer.
Unread 07-26-2007, 10:37 AM   #10
Krazybones
DEEEZ NUUUTZ
Krazybones's Avatar
That sucks, mine is not like that and all seperate.
Unread 07-26-2007, 10:41 AM   #11
Sometimes I just really want to rip this fucking pool down! I spend WAY more time cleaning it and/or fixing some part of it than I do enjoying it.
Unread 07-26-2007, 10:49 AM   #12
Krazybones
DEEEZ NUUUTZ
Krazybones's Avatar
I said the same thing when we got ours... I got it down to a science now, besides my girls would kill me if I did that! She doesnt tell me to get rid of my toys , but I know what ya mean.... Best thing I bought for it was a cheap timer for the filter/pump ($20)
Unread 07-26-2007, 10:55 AM   #13
Joe5.0
Co-bah-ras & Chicks Mix rules!
Joe5.0's Avatar
Joe5.0 I need rep points!
I once used a solder gun to melt plastic together, worked pretty well actually.
1995 Ford Mustang Cobra
Forged 347 ~ Edelbrock RPM intake ~ Edelbrock heads ~ Crower cam ~ Detroit locker rear end ~ 17x11 & 17x9.5 TTII's ~ Tremec 3550 ~ Springs, Adj shocks, & Panhard bar
2003 Acura 3.2 CL Type-S -------- 14.0 @ 98.8 mph --- 218whp - 206wtq
6 Speed w/LSD ~ 19" Chrome Zenetti's w/Pirelli rubber ~ H&R Sports w/Tokico Illumina's ~ Lightweight 17's w/BFG DR's ~ Comptech Intake ~ JL 13W7 & 1000.1 Amp
Pics & Vids
Joe5.0 is offline   Reply With Quote
Unread 07-26-2007, 11:00 AM   #14
Wife has used the pool maybe 2 times this summer. Alexia however I can't keep her out of it. That timer is a great idea. Do they make timers that take a 220 plug? If they do, I haven't seen one. I'll search Lowes.com for one right now.
Unread 07-26-2007, 11:01 AM   #15
That's pretty fucking genious! I threw mine at a wall last year so maybe I will pick up a new one tonight.
