Unread 07-14-2007, 11:59 PM   #1
PurpleHaze
PurpleHaze's Avatar
PurpleHaze I need rep points!
Exclamation Firepower MIG Welder
New never used.
Firepower MIG Welder - 155 Amp 230V - FP160: The FP160 offers industrial quality 230 volt performance in a compact portable package. Industrial performance Uses standard 230 volt single phase current Heavy-duty wire feed system Increased welding capacity Dual Purpose - Can used to weld with or without sheiding gas (welds with solid or flux cored wire) 2 lb and 10lb wire spool capacity Four position welding power output control Infinite wire speed adjustment Illuminated on/off switch Illuminated thermal overload indicator Thermostatic heat protection 5-2-1 Firepower. Comes complete with: Genuine Firepower argon regulator, 10 ft. Genuine Tweco MIG gun, 6 ft. Ground cable, 6 ft. Power cable with plug, welding nozzle and tip, spool of. 030 MIG welding wire, instruction manual Specifications: Input voltage - 230V 60HZ Input current - 20 Amps Welding output voltage - 30V Maximum output amps - 155 Amps Open circuit voltage - 30V Rated output amps - 130 Amps 20 duty cycle Maximum thickness capacity - 3/8 inch Weight - 60 lbs.
NEEDS GO FOR IRS FIRE SALE
$350.00 OBO
PurpleHaze is offline   Reply With Quote
INDUSTRIAL MIG WELDER (MILLER) Boomer! Classifieds 0 04-02-2007 04:00 PM
Still need a welder.. Xx96GTxX The Alley 14 05-13-2006 08:43 AM
