Go Back   Detroit Racing Forums > General Discussion > The Gym
Unread 07-10-2007, 08:43 PM   #1
77sportcompact
King Griffin Racing
77sportcompact's Avatar
77sportcompact I need rep points!
Default weight is being added
well everyone is talking about losing weight. i have stayed the same since dec. but i keep adding weight to all my workouts. i way 207lbs, i'm repping 300lbs in bench, 325 in squat, 610 in leg press, 145 in staitbar curls, 365 in straitbar shrug, 205 in miltary press, and little more then norm in all other lifts.
i swear its's stock, as long as highly modifications are stock
77sportcompact is offline   Reply With Quote
Unread 07-23-2007, 09:36 AM   #2
LITTLEMAGS
LITTLEMAGS's Avatar
LITTLEMAGS I need rep points!
man...nice lifts...
LITTLEMAGS is offline   Reply With Quote
Unread 07-23-2007, 09:49 AM   #3
Not bad numbers.
I'm currently 228lbs.
Rep 325lbs on flat bench
Rep 375lbs in squats
Rep 1075lbs on leg press
Rep 495lbs on straight bar shrugs
And for what it's worth my "reps" consist of at LEAST 10 true reps in any set
Unread 07-23-2007, 10:08 AM   #4
LITTLEMAGS
LITTLEMAGS's Avatar
that is big weight AL
2004 mach 1..
stroked 4.6 F1a cog
735rwhp/585 tq for now....
Unread 07-23-2007, 10:13 AM   #5
Thanks. My bench is the only one that fluctuates. Depends on how badly my right elbow hurts. It's come to the point where I went from single-handed curling 75lbs to not being able to single-hand curl 35lbs. I have been getting some treatment for this but it's a slow process. I can still curl the crooked bar just fine, almost no weight has dropped off that, but when I go to use one hand life sucks.
Unread 07-23-2007, 11:24 AM   #6
LITTLEMAGS
LITTLEMAGS's Avatar
still strong though!
2004 mach 1..
stroked 4.6 F1a cog
Unread 07-23-2007, 02:00 PM   #7
Thank you.
Almost at my weight goal ... Golden The Gym 8 05-25-2007 09:58 PM
Weight bench and free weights for sale, CHEAP jsxtreme Classifieds 3 05-11-2007 03:43 PM
FS: 2 weight benches Lisa Classifieds 2 05-10-2005 04:59 PM
Added some avatars... Lisa The Alley 14 03-01-2005 04:32 PM
