Unread 06-10-2007, 07:03 PM   #1
Default Hyd. Roller Turbo camshaft and brand new tie-bar style hyd. roller lifter for SBF
Small hyd roller turbo cam, designed for a 347 with very mild TW heads. Made 950+HP @ 20psi, shifted at only 6200rpm. $200 obo.
Brand new, never used tie-bar style hyd roller lifters for SBF, these are the tie bar style hyd roller lifters, can be using in an older non-roller style block if using a standard hyd-roller sbf cam. Can also be used in a roller block to get more power and RPM over the stock style lifters. This set is brand new and has never been run, only mocked up in a motor which was never fired. PM with offers please.
Unread 06-21-2007, 08:39 AM   #2
ttt
