Unread 05-29-2007, 08:58 PM   #1
Kevs86GT
Kevs86GT I need rep points!
Confused Tranny help
I was out driving the mustang today and mentioned to my daughter that something wasn't feeling right with the response of the car and tranny. No sooner had I said it and gave it a "little" gas there was a clunking noise in the tranny and the car began to buck.
I pulled over and looked under the car and there was no fluid leak, I checked the clutch cable which is adjustable and while the car was off I put the shifter into each gear and tried to push the car back and forth to see if trans was holding(it was).
After starting the car and attempting to engage the clutch the clunking sound was evident, this happened in all gears as well as neutral.
What could this possibly be and what do I look for when I pull the tranny out.
Kevs86GT is offline   Reply With Quote
Unread 05-29-2007, 09:26 PM   #2
Make sure it's not the rear end, the symptoms can be similar.
Unread 05-29-2007, 10:20 PM   #3
Kevs86GT
It's happening at the bellhousing. I get this clunking whenever I try to release the cluth pedal and this happens if I am in neutral or in gear.
Unread 05-30-2007, 01:25 PM   #4
Rickety
Rickety's Avatar
Rickety I need rep points!
Sounds like yer Inputshaft is broken......
What trans???
Rickety is offline   Reply With Quote
Unread 05-30-2007, 04:56 PM   #5
Kevs86GT
If that is the case? then what are my options?
Is this a rebuild or just a replacement?
This is a T-5 tranny.
Unread 05-30-2007, 06:50 PM   #6
To me it sounds like the input shaft bearing retainer.
Unread 05-30-2007, 08:23 PM   #7
Kevs86GT
Will try to pull tranny soon, never did this before with a manual. Just wondering what to expect or look for.
Any suggestions or advice? Would be appreciated............
Thanks
Kevin
Unread 05-30-2007, 10:40 PM   #8
Rickety
Rickety's Avatar
If it's the inputshaft....Then It prolly took out the cluster....$$$$$$$$
Yank the trans out and take it to D&D in Wixom....Speak with Joe... He should be able to quote ya something.....
Torino Tranny 4 cam tbird The Alley 7 11-19-2006 02:34 PM
finally got a tranny... nitrous_bob The Alley 15 01-26-2006 05:45 PM
I managed to get my motor back in Psyco Diver 69 The Alley 4 08-17-2005 06:42 AM
Norwalk track ate my tranny!! XTCNAGT The Alley 9 07-12-2005 05:30 PM
Tranny shops 1Quick88 The Shop 10 02-14-2005 08:49 AM
