05-09-2007, 04:29 AM
Banned
need help please with a running problem??
its a 88 gt 5.0 all stock.heres what its doing,the idle gos up and down(900 to 400 rpms) everytime on start up,even when its warm.no matter what speed im at 20 30 or 40 mph,if i hold it there it acts like it wants to miss or buck on me till i hit the gas about half way down then its fine.when it acts up like that and i push the gas half way or to the floor to get it to stop it will pop through the intake once in a while and when i let it idle too long the rpms will go up and down and sometimes the rpms will stay around 1200 and when that happens ill turn the car off and restart it and the idle gos to normal(900)after it stops going up and down.i noticed when i put it to the floor(wot)it dont pull like it should and sometimes it kicks in like its running on 6 cyls and the other 2 kick in.its like a v6 on nos but you never know when the nos is going to kick in.parts replaced=fuel pump reg,full tuneup,fuel filter,timing chain and every gasket on the motor,Parts cleaned= egr,iac,tb.car has 33 psi of fuel press at idle, jumps up to 40 when i hit the gas and its at 41 with the vac line off.it ran the same way be 4 i replaced all the parts.anyone??maby injectors???
05-09-2007, 02:57 PM
Infraction Jackson !!!!!!
Actually when I had Steves car here it did the same exact thing, when he put the plug wires on the passenger side he did not have then all the way down in the hole (modular engine) You may want to check for a bad wire or be sure your plugs are at the correct gap,double check the cap and rotor timing ect. If you want shoot me a call or PM, tonight I'll swing by if it quits raining and bring my vacuum gauge and see how much vacuum your pulling.
Later,
Boomer
05-12-2007, 11:24 PM
Banned
Later,
Boomer
me and steve might have to line em up one day.i think that will be a good one for me b-4 the blower gos on  .honestly,i think it will be a good one.
05-13-2007, 03:23 PM
I thing you'll take him, his car is heavier and has a little les power than yours. It would be a fun race, now I can can get something together beore the end of the summer you have a race. I'll run my little 281 2 valve against yours with the blower, that is only if I don't go tube chassis and get one built in time. What do you think ? 335 rwhp (  ) gutted 96 against your ride? Do I hear a call out ? LOL
05-13-2007, 10:03 PM
Banned
sounds good to me
