Unread 02-04-2007, 06:35 AM   #1
88 gt
Banned
88 gt's Avatar
88 gt I need rep points!
Default sbf roller rocker help
has anyone ever used these "Cat Small block ford roller tip rockers,1.7 ratio"?if so,will i be fine useing them with edelbrock rpm heads with 202 valves and a b-303 cam on my stock 88 302 short block?heads have Dubble valve springs good for a little over a 600 lift cam and my cam is a 480 lift?
88 gt is offline   Reply With Quote
Unread 02-04-2007, 06:53 AM   #2
The springs might be too much for that cam. ALso make sure you check piston to valve clearance with those 2.02's.
Unread 02-04-2007, 07:14 AM   #3
88 gt
Banned
88 gt's Avatar
what size rockers will i be safe with??i had a guy that wanted to trade me his cast iron dart jrs for mine and he stoped sending pms so i guess ill have to put these big fu@kers on my car.dennis had a b-303 cam in his car when he had these heads on it.
Unread 02-04-2007, 07:53 AM   #4
If Dennis has stock pistons and got away with it then you'll be fine.
You got em on yet or are you still f'in around? lol
Unread 02-04-2007, 10:39 PM   #5
88 gt
Banned
88 gt's Avatar
i didnt mean the rockers i ment he had a b-303 cam in his car with the same springs...Im taking the head to my buddy monday and i should have it back by wed or thursday.i wish i had a place to work on it ,to cold out side .
Unread 02-05-2007, 08:23 AM   #6
It's always a good idea to check piston to valve just to be sure.
81 z28 roller daveg Classifieds 0 08-03-2006 10:46 AM
SBF heads and 1.6 Roller rockers for sale. Casper302 Classifieds 0 04-08-2006 09:32 AM
PERFECT 1967 mustang roller DarkoStoj Classifieds 3 07-22-2005 06:40 PM
SBC Hydraulic Roller Lifters and other Strtracer Classifieds 1 03-08-2005 05:54 PM
