Unread 11-14-2018, 11:57 AM   #1
Default SEMA 2018: COMP Cams BSR Shaft Rocker System for LS Engines
COMP Cams has come out with a new shaft rocker system for LS1, LS3, and LS7-style heads. It uses a solid bearing and a forced oiling system with an OEM rocker body, for improved high-lift and high-RPM performance.
SEMA 2018: Hotchkis Sport Suspension?s Bluetooth-Controlled System NewsBot Street Legal TV Newsfeed 0 11-12-2018 08:00 AM
SEMA 2018: Comp Cams BSR Shaft Rocker System for LS Engines NewsBot Dragzine Newsfeed 0 10-31-2018 07:32 PM
SEMA 2018: Comp Cams BSR Shaft Rocker System for LS Engines NewsBot Street Legal TV Newsfeed 0 10-31-2018 07:32 PM
LS Rocker Arm Tech with COMP Cams NewsBot Dragzine Newsfeed 0 05-02-2014 07:44 AM
Comp Cams Shows How a Camshaft is Made NewsBot Street Legal TV Newsfeed 0 07-19-2010 11:54 AM
