SEMA 2018: Comp Cams BSR Shaft Rocker System for LS Engines
Comp has come out with a new shaft rocker system for LS1, LS3, and LS7-style heads. It uses a solid bearing and a forced oiling system with an OEM rocker body, for improved high-lift and high-RPM performance.
