Unread 09-08-2006, 07:46 AM   #1
Exclamation Automatic transmission needed ASAP!!!
My next door neighbor's transmission in his wife's 1997 F-250 went out the out day and he's very straped for cash and needs a reliable replacement, and cheap. Can anyone help me? If I am not mistaken the trans needed is a E4OD...right? Some of you would probably know better than me.
Can anyone help?!?
Thanks.
Unread 09-08-2006, 07:54 AM   #2
Have him pickup a copy of the Tradin Times paper, there are usually deals in there.
Unread 09-08-2006, 08:01 AM   #3
www.car-part.com looks up local and nationwide salvage yards.. however i worked at a trans shop back in the day and a vast majority of used transmissions never worked right or didn't hold up long if they did work.
Unread 09-08-2006, 08:36 AM   #4
Boomer!
Infraction Jackson !!!!!!
Boomer!'s Avatar
Boomer! I need rep points!
Can anyone help?!?
Thanks.
Yes it should be a E4OD, finding a good used unit may be tough. The place to check for a rebuild is Roseville transmission. I had a trans rebuilt there a your ago and they were far cheaper than anywhere else I found .
Boomer! is offline   Reply With Quote
Unread 09-08-2006, 08:50 AM   #5
His wife told me that the when the tow truck driver came to pick up the truck to bring it to their house he noticed that there wasn't a drop of trans fluid in the trans. They park their trucks in their driveway and there is no trans fluid in the driveway anywhere and the truck had a trans fluid change a month or two earlier. WTF?!?!?
What do you think a rebuild from Roseville Transmission would cost?
Unread 09-08-2006, 09:25 AM   #6
4 cam tbird
4 cam tbird's Avatar
4 cam tbird I need rep points!
Have they just tried throwing some tranny fliud in it first? Might be worth a shot. I've got a C4, but I don't think it would bolt up The computer definitely wouldn't be happy.
Pictures, pictures, pictures!
4 cam tbird is offline   Reply With Quote
Unread 09-08-2006, 09:30 AM   #7
Is it 2 or 4wd??
Heres a break down of a typical rebuild:
R&R trans ($350 2wd, $450 4wd)
Overhaul kit ($200-350)
Bench labor ($300-$500)
Torque converter ($150-$250)
Fluid ($25-$40)
This is just an example. If it has hard part failure the price goes up from there.
Unread 09-08-2006, 04:34 PM   #8
Is it 2 or 4wd??
Fluid ($25-$40)
4WD
4 cam tbird. I doubt trowing some tranny fluid would help. Plus, they are in the process of seeing what the "quick lube" place will do about the truck...if they do anything. They had a problem once before with another tranny place who put the wrong pan back on after a repair and they (tranny place) ended up having to front the bill for a new trans.
Unread 09-08-2006, 08:25 PM   #9
ReiKo
Pyrotechnician
ReiKo's Avatar
ReiKo I need rep points!
If they need a rebuild... I have a shop that will give them a hell of a break... Only thing that sucks though... That trans takes around 20 quarts of fluid...
ReiKo is offline   Reply With Quote
Unread 09-08-2006, 11:17 PM   #10
What shop and how much?
Unread 09-09-2006, 12:59 AM   #11
ReiKo
Pyrotechnician
ReiKo's Avatar
The trans would have to be seen by him first to get a estimate cause of the parts involved... I will call him monday...
Unread 09-09-2006, 05:49 AM   #12
4WD
Good luck with the quick lube place admitting fault. Most people I know end up taking them to court and never seeing the full amount.
Unread 09-09-2006, 12:52 PM   #13
I just need a ballpark estimate. My neighbor doesn't have the time or patience to be pulling trans and driving it around for everyone to see. He just needs it fixed right, fast, and cheap.
That's what I told them.
