Unread 03-02-2006, 06:59 PM   #1
redhotstang001
redhotstang001's Avatar
redhotstang001 I need rep points!
Default Electric Fan Help
Have to replace water pump and when i doing that i would like to change to an electric fan setup... What brand or type should i go with.. i was thinking of
Proform Electric Fans
Electric Fan, Single, 15 in. Diameter, Puller, 2,800 cfm, Black, Plastic, Ford, Mustang, Kit
Any help would be nice... this is from summit racing site
Shane
1988 Ford Mustang GT
PHOTOS
Best Time 1/4 Mile: 13.73@ 99.76
redhotstang001 is offline   Reply With Quote
Unread 03-02-2006, 07:04 PM   #2
Try www.detroitspeedshops.com and see what they have. Just make sure you get the biggest fan that'll fit in that space.
Unread 03-03-2006, 02:57 AM   #3
redhotstang001
What a day....
Just needed to replace water pump and ended up with more problems. got all the bolt off and the last one i broke Now i have to try and gt the bolt out without removing th timing cover.. hoping i can do that.. Nothing can be easy for me to fix....
One thing is if the cover has to come off i'll put some new part on her, maybe a cam, new timing chain, and some pulleys.. just have to see...
Shane
PHOTOS
Unread 03-03-2006, 03:17 AM   #4
Fordgazm
Fordgazm's Avatar
Fordgazm I need rep points!
sell it to me for 50 bucks Shane and buy a civic
I have a bunch of parts from a 92 gt in the garage , I guess I'll call it a car
Fordgazm is offline   Reply With Quote
Unread 03-03-2006, 07:19 AM   #5
Originally Posted by redhotstang001
What a day....
It probably broke because its so cold outside. Try soaking it in PB Blast for a day or two before you mess with it again.
Unread 03-03-2006, 03:31 PM   #6
redhotstang001
You wish jason, maybe if your trade your house...
I'll try that and see what happen have to work the next two days so it will have some time have to see.
Shane
PHOTOS
Unread 03-12-2006, 01:03 AM   #7
redhotstang001
well didn't get the fan yet but i did get the car water pump on and running and i also installed the Adjustable Clutch Cable and Quadrant Kits. very cool
Shane
PHOTOS
Unread 01-31-2007, 12:59 AM   #8
fast89gt
fast89gt's Avatar
fast89gt I need rep points!
hay man if you want a good electric fan get one from a 3.8 Taurus i have one and it keeps my engine real cool, has matter of fact, i have it on the lowest setting too!!
white 89 Mustang GT
fast89gt is offline   Reply With Quote
Unread 01-31-2007, 08:07 AM   #9
blk00rt
blk00rt's Avatar
blk00rt I need rep points!
What a day....
can you reach the bolt easliy, an old mechanics trick is to carefully weld a nut on top of the bolt pieces that remain and then back it out with a wrench. I have had to do that on bolts that broke below the surface before. but you have to be careful when doing this trick.
I had an electric fan on my truck and could not keep it cool so I had to put the mechanical fan back on. I have a 2950 cfm electric permacool fan. Electric fans are good to be used mixed with a mechanical fan but if you do a lot of traffic sitting then the electric fans are not that good on v-8s of course this is just my thoughts
Rob Dunn
2000 Dakota RT
12.2 @ 105 mph
blk00rt is offline   Reply With Quote
Unread 01-31-2007, 08:51 AM   #10
This thread is almost a year old
Unread 01-31-2007, 03:19 PM   #11
And still going.
Unread 07-10-2007, 10:21 PM   #12
MotownZ
MotownZ's Avatar
MotownZ I need rep points!
oo
MotownZ is offline   Reply With Quote
WTB: Cheap inline electric fuel pump.. BigWheelinBubba Classifieds 4 09-30-2005 09:56 AM
