Originally Posted by johnquick302
you can mess with the duration with lash too. every .004 is 1 deg of duration.
if you have a cam card you can multiply lobe lift by the rocker arm length. if it says .450 you multiply that at 1.6 and it equals .720 lift or 1.7 is .765
Does that pertain to Solids only, or does it also affect (most likely not as much) Hydraulics? I.E. Valve lifter preload being .050 if you go to .075 would that affect the duration? Also do you have a tech article on this?
Thanks Roger
(the numbers are just examples)
