Unread 08-06-2014, 12:13 PM   #1
Default Quick Hit Tech: Valve Spring Tech With Lunati
If you install valve springs and you aren't checking the machining clearances, valve spring pocket clearances, retainer fit or installed height, then you need to check out what our friends at Lunati advise.
Proform Releases New Pneumatic Valve Spring Compressor NewsBot Dragzine Newsfeed 0 04-26-2013 04:49 PM
Get Maximum Valvetrain Control with Lunati Signature Valve Springs NewsBot Dragzine Newsfeed 0 06-01-2012 05:46 PM
Video: COMP?s Tips to Maximizing Valve Spring Life NewsBot Dragzine Newsfeed 0 05-17-2011 12:20 PM
How To Set And Adjust Valve Lash Like A Pro NewsBot Street Legal TV Newsfeed 0 06-24-2010 04:01 PM
FS: Brand New SBF Mahle piston & ring kits jsalvato1 Classifieds 0 03-13-2009 05:45 PM
