Unread 01-11-2005, 02:28 PM   #1
Default Anybody know of good 351W Headers???
Whats a good Full-lenght header for a 351w w/ c4? I know MAC headers have got to be the biggest pain in the ass to install/uninstall I've seen. Anybody use anything else? Looking for 1 7/8". Also trying not to go the custom route to much $$$). Any ideas would be helpful. Thanks.
Unread 01-11-2005, 05:03 PM   #2
All long tubes are hard to install on a Fox chassis, if thats what you have. There is just not alot of room to run 4 tubes thru that opening and keep everything equal length. 1 7/8 are gonna be a huge problem, most consider 1 3/4's as the biggest unless you change the k member or go custom. Kook's probably makes a set of 1 7/8, but they aint cheap($600 and up). BBK makes a 1 3/4 shorties for the 351, theyre around $400.
Unread 01-11-2005, 05:42 PM   #3
Default Headers
Yeah I figured I'd have to spend more than $400. I just don't want to spend $1000 on a set of headers. I did change the k-member so I'd have more header clearance (and for weight). I may try to look for a used set of Kooks headers on some mustang sites. Thanks!
Unread 02-01-2005, 12:28 AM   #4
Puma
Puma I need rep points!
kooks definitly fit the best and are very easy to install. I have had the hookers and hedmans but the kooks are wayyy better, definitly worth the extra cash.
Puma is offline   Reply With Quote
Unread 02-01-2005, 09:13 AM   #5
Default Headers
Cool thanks. I'm guessin the chance of finding a use set of kooks is about zero?
Unread 02-01-2005, 05:04 PM   #6
Puma
Try checking out the classifieds at Hardcore50, NMRA & FFW, might find something there. BTW, what head are you using??
Unread 02-03-2005, 09:57 AM   #7
Default Headers
Planned on using a victor jr (60cc). Haven't picked them up yet though.
