Unread 01-08-2005, 07:19 PM   #1
Default 87-93 Mustang 5.0 and 302 parts
Please PM me if you are interested in any of the following. Everything is first come first serve, no holds unless you put a cash deposit down
All New In sealed packages:
Crane Adjustable FPR #99471-1 $99.95.……$75
BBK 190LPH Fuel Pump $129.88.…….$100
New, never installed, no packaging:
87-93 LX Front Fascia $209.95.…….$170
Fascia Support $85.…………………$70
Goodyear High miler(Blue) hoses, no upper hose, has lower ,bypass ,and 2 lengths of heater hose $50
T-5 Parts:
Cases, shafts, gears, input and output shafts, sliders, bell housing, fork,factory shifters and shifter plates( no pedal assm.),tail shafts.
T5Z- 1000 miles, bought new from D&D for $1200....$800 obo
Used:
Rt&Lft front lower contol arms with spindles(upgrade your 86 and earlier to the 87 and up brakes) $50
91 Front left fender from a GT (dark blue) excellent condition $70
4 16” Silver Pony rims. 1 has 2” of curb rash, 4 lug no centers $175
Reman 91 Alternator with under drive pulley $50
K&N filter for stock air box $20
Stock 5.0 HOEFI conversion pieces:
Upper and Lower Intake, E7TE heads, fuel rail, 60mmTB, stock Maf, air box, connectiong hoses, stock alternator, water pump and crank pulleys, water pump, 110lph pump, factory headers. No wiring harness, distributor, or computer. Stock cat H-pipe. All or parts, make offers.
Carbed 302 parts
Accel Dual Point distributor $25
1 pair of D80E heads $40
302 Longblock, rebuilt, less than 1000 miles, 1978 truck motor, set up for carb, has mechanical fuel pump. Rebuilt to stock specs. Good starting point for a mild build up, or replace your worn out motor in your driver. $400
ALL PRICES ARE OPEN TO OFFERS
Again, if you are interested, please PM me for quicker response
Unread 01-10-2005, 02:50 PM   #2
Pics available
Unread 01-11-2005, 12:36 PM   #3
HPM driveshaft loop #4000-AZ $39.00.……$25
Flaming River Steering Shaft for Power rack FR1504P $174.95.….$150
Energy Suspension Steering Rack Bushings $10.95......$5.00
FMS 24LB injectors $219.88 …….$150
Moroso Battery box $96.95.……….$75
T-5 Parts:
Cases, shafts, gears, sliders, bell housing, fork,factory shifters and shifter plates( no pedal assm.),tail shafts.
King Cobra clutch and pressure plate, 80% left, with NEW throw out and pilot bearing $100
Used:
Rt&Lft front lower contol arms with spindles(upgrade your 86 and earlier to the 87 and up brakes) $100pr
91 Front left fender from a GT (dark blue) excellent condition $85
4 16” Silver Pony rims. 1 has 2” of curb rash, 4 lug no centers $225
4 15” American Racing Rims, Gold center w/polished rim, 4 lug with
225/60/15 tires (off brand, 50% tread) $125
K&N filter for stock air box $25
Upper and Lower Intake, E7TE heads, 19LB injectors, fuel rail, 60mmTB, stock Maf, air box, connectiong hoses, stock alternator, water pump and crank pulleys, water pump, 110lph pump, factory headers. No wiring harness, distributor, or computer. Stock cat H-pipe. All or parts, make offers.
Carbed 302 parts
Edelbrock Performer Intake #2121 $75
Holley 600 CFM Carb W/electric choke $75
Edelbrock Signature 14”x2.5” Chrome Air cleaner $25
Rebuilt 302(1978) long block w/less than 1000 miles $450
Mike, I will take that clutch and plate. Send me your info and how much shipping will be. Money will be sent friday morning. As you could understand with every thing that's going on
bmxrider_03@hotmail.com
Unread 01-11-2005, 01:37 PM   #4
Check your email Randy.
Unread 01-11-2005, 02:50 PM   #5
Had some requests for pics, here they are
Unread 01-12-2005, 08:01 PM   #6
sold
Unread 01-12-2005, 10:53 PM   #7
Joe5.0
Co-bah-ras & Chicks Mix rules!
Joe5.0's Avatar
Joe5.0 I need rep points!
Will the DS loop fit a SN95? I think the floorpans are the same, not sure tho.
1995 Ford Mustang Cobra
Forged 347 ~ Edelbrock RPM intake ~ Edelbrock heads ~ Crower cam ~ Detroit locker rear end ~ 17x11 & 17x9.5 TTII's ~ Tremec 3550 ~ Springs, Adj shocks, & Panhard bar
2003 Acura 3.2 CL Type-S -------- 14.0 @ 98.8 mph --- 218whp - 206wtq
6 Speed w/LSD ~ 19" Chrome Zenetti's w/Pirelli rubber ~ H&R Sports w/Tokico Illumina's ~ Lightweight 17's w/BFG DR's ~ Comptech Intake ~ JL 13W7 & 1000.1 Amp
Pics & Vids
Joe5.0 is offline   Reply With Quote
Unread 01-12-2005, 11:27 PM   #8
Tag on box says 79-96.
Unread 02-11-2005, 07:17 PM   #9
Insulating my garage, need this stuff out of my way, reasonable offers????
Unread 02-28-2005, 03:45 PM   #10
Updated the ad
