Unread 05-28-2013, 07:50 PM   #1
Default Wilwood?s Swing Mount Brake & Clutch Pedal Kits
Wilwood's new swing mount pedal kits fit into a wide range of applications. Whether it's a racecar, street rod, or Pro Touring vehicle, you owe it to yourself to take a closer look. It's got an adjustable design to tweak pedal location, and the options for where the master cylinders mount.
Direct Fit Brake and Clutch Pedal Arms for 67-72 Chevy/GMC Trucks NewsBot Street Legal TV Newsfeed 0 04-24-2013 04:25 PM
SEMA 2012: McLeod?s Expands Hydraulic Clutch Conversion Kits Line NewsBot Street Legal TV Newsfeed 0 11-05-2012 07:55 PM
Adjustable Reverse and Forward Mount Pedal Assemblies from Wilwood NewsBot Dragzine Newsfeed 0 04-27-2012 01:50 PM
Keep Your Release Bearing Alive With The Ram Clutch Pedal Adjuster NewsBot Dragzine Newsfeed 0 03-01-2011 08:32 PM
Keep Your Release Bearing Alive With The Ram Clutch Pedal Adjuster NewsBot Dragzine Newsfeed 0 03-01-2011 07:44 PM
