Unread 08-09-2005, 01:51 PM   #1
Racingqtrsstang
Racingqtrsstang's Avatar
Racingqtrsstang I need rep points!
Default Steeda Clutch Cable
What are your guy's opinions on the steeda clutch cable kit? I'm thinking about going with that for dennis "stangracer" car. It's like 100 bucks over at stangnet
Racingqtrsstang is offline   Reply With Quote
Unread 08-09-2005, 02:01 PM   #2
99SVTAddict
99SVTAddict's Avatar
I went with the UPR clutch quadrant and firewall adjuster.
I've heard many stories about aftermarket cables snapping.
BTW, UPR and Steedas clutch quadrant and firewall adjuster is basically the same.
99 SVT Cobra Mustang
*A couple of modifications
Unread 08-09-2005, 02:08 PM   #3
Racingqtrsstang
Soo basically i need to get a firewall adjuster with it also?
Unread 08-09-2005, 03:15 PM   #4
99SVTAddict
The firewall adjuster allows you to slightly change the point where the clutch grabs (related to the clutch peddle position). The stock one is plastic/rubber and is non adjustable.
The UPR or Steeda clutch quadrant is a vast improvement. The stock one is plastic with little teeth on it. The manual tells you after xxx amount of miles to pull up on the peddle and it will self adjust itself. What you are actually doing is repositioning where the cable is on the quadrant since it has skipped across some of those teeth over time. I think this was my problem at the track. Dumping the clutch at 6,000 RPM's on ET Streets and the quadrant teeth couldn't hold onto the cable (something like that). The new quadrant is made of aluminum and has one setting. Much stronger piece.
The OEM cable from everything I've heard and read are STRONG. But like I said, I've heard multiple stories of aftermarket cables fraying or snapping.
So yes, I'd recommend the firewall adjuster AND clutch quadrant.
Unread 08-09-2005, 09:33 PM   #5
Racingqtrsstang
Thanks for the advice
F-body tuning cable firebird355 Classifieds 0 07-03-2005 12:05 AM
BBK Cable and MSD Blaster 2 Coil 4 sale. Casper302 Classifieds 1 05-14-2005 04:08 PM
Larry the Cable Guy Ticket Available!! 1Quick88 The Alley 11 03-14-2005 02:52 AM
Electrical cable and.. Strtracer Classifieds 0 03-11-2005 06:18 PM
