Light-Weight Starter for the Ford Coyote 5.0 from Powermaster
Got some high compression goodies in your Ford 5.0 Coyote engine? Not only will this starter give you the cranking power for engines with up to an 18:1 compression ratio, it will also give you severe weight savings with its 8-pound design.
