Unread 01-04-2012, 09:53 AM   #1
YOUNG EXEC
YOUNG EXEC I need rep points!
Default engine swap
OK I have a 95 Chevy 1500 truck with a blown v6 and I bought a motor from a 97 Chevy 1500 I have the wiring harness and pcm my problem is I don't know where to start the on the install Ive gone as far as to pull the blown one out sit it side the new one and nothing is the same I can install the new motor but the harness and pcm I have no clue.Any help would be appreciated
YOUNG EXEC is offline   Reply With Quote
Unread 01-05-2012, 09:57 AM   #2
What do you mean by "nothing is the same" ?
Is it a V6 also? If so, I would try to move stuff over from the old engine so that you can use the existing harness and PCM. That would be the easiest way. In other words, move the intake manifold and sensors from the old engine to the new one, so that you can use the existing harness and PCM.
Unread 01-09-2012, 08:45 PM   #3
1BADAIR
FLOORMAT RACING
1BADAIR's Avatar
1BADAIR I need rep points!
96+ are vortec heads.
are they both l35's?
11's in 011
1BADAIR is offline   Reply With Quote
Unread 01-14-2012, 07:03 AM   #4
565bbccarbed
565bbccarbed's Avatar
565bbccarbed I need rep points!
Default differences .
The motors may be different by heads up - meaning your 95 block has different heads and intake manifold to the newer motor .I dealt with the astro van some and the "w" heads have a totally different top end .you should be able to make something happen ,but if it is TBI injection going to SFI injection .You may have to do a heads and intake swap then reinstall .Good luck
565bbccarbed is offline   Reply With Quote
With New Engine Coming, Glidden Staying The Course In Ever-Changing Extreme 10.5 NewsBot ADRL Newsfeed 0 04-05-2011 07:16 PM
How To Set And Adjust Valve Lash Like A Pro NewsBot Street Legal TV Newsfeed 0 06-24-2010 04:01 PM
Engine Building Tips Part 1: Oiling System, Valvetrain Stabilizers, and Geometry NewsBot Street Legal TV Newsfeed 0 06-24-2010 02:52 PM
Preparing Your LS3 For Surviving Boost NewsBot Street Legal TV Newsfeed 0 06-15-2010 06:10 PM
Team MSD claims Hot Rodders of Tomorrow Engine Challenge NewsBot Street Legal TV Newsfeed 0 06-08-2010 12:39 PM
