Unread 11-08-2011, 07:29 PM   #1
Default SEMA 2011: Dart?s New Budget SHP Cylinder Heads; Assembly Lube
New to Dart's SHP line is a cast A356-T6 aluminum small block Chevy cylinder head that is designed to work with most off the shelf components, and features 180cc or 200cc intake runners. Also, Dart's High Performance Assembly Lube is designed for mechanics and technicians to pre-lube bearings, cams, lifters, etc.
SEMA 2011: Edelbrock?s Super Victor Manifold for BBC Heads NewsBot Dragzine Newsfeed 0 11-07-2011 05:32 PM
SEMA 2011: Trick Flow?s Twisted Wedge CNC Heads Improved Design NewsBot Dragzine Newsfeed 0 11-06-2011 07:26 PM
SEMA 2011: Trick Flow?s Twisted Wedge Series Heads Improved Design NewsBot Dragzine Newsfeed 0 11-06-2011 05:06 PM
Ultimate Guide to Budget BBC Cylinder Heads Under 2k NewsBot Dragzine Newsfeed 0 07-29-2011 01:30 PM
Ultimate Guide to Budget BBC Cylinder Heads Under $2,000 NewsBot Dragzine Newsfeed 0 07-29-2011 11:13 AM
