Unread 05-27-2005, 06:21 AM   #1
88lxbrian
88lxbrian I need rep points!
Default water pump question
I am switching the water pump on my new setup. Instead of it being the regular counter-clockwise water pump, I want to switch to the standard rotation (clockwise) pump. I pulled out all of my extras so all I have now is my crank, alternator, and water pump.
Is a performance water pump the only way to get rid of the heater core hookups?
88lxbrian is offline   Reply With Quote
Unread 05-27-2005, 06:04 PM   #2
No, you can buy rubber caps at Murrays for a couple bucks, or you can pull out the pipes on the pump and tap in freeze plugs, but I wouldnt go that route
