05-26-2005, 09:27 AM
Bump Steer Alignment Shop in Michigan
I have purchased the baer tracker bump steer kit for my lowered fox body mustang. I need a local shop in michigan that can align for bump steer. Anybody know of any in lower michigan. I live in Flint but work in Southfield so any where in between there would work. Thanks in advance.
1988 LX 5.0 5 Speed Hatch
Taylor Pro 409-Hypertech Coil-MSD Cap
World Class T-5-Energy Suspension All Mounts and bushings-D&D Performance Short Throw Shifter
BBK Unequal Length Ceramic Shorties, BBK X-Pipe, Flowmaster 2.5 American Thunder w/ Stainless Tips
Densecharger CAI-MRT Street Springs w/ Tokico 5 way-Baer 5 Lug 4 Disc w/ Drilled Slotted-Baer Tracker Bump Steer-5 Lug Saleen 18x9 Polished Relpicas-Moog Ball Joints
218/287 RWHP/RWTQ
Future
65 MM BBK TB
Cobra R Intake.
05-26-2005, 10:18 AM
Belle Tire should be able to do it... if not try Slims Hot Rod Shop in Eastpointe.
05-26-2005, 10:25 AM
I wouldn't get Belle-Tire to even alighn my car after I put a new 90/10 struts on. They told me the struts were bad. This after they had the car for 3 hours! I'd go w/ Slims. Too many dumbass kids at some of the local tire places!
05-26-2005, 10:33 AM
I have a buddy thats a manager at Belle Tire on Hall Rd. & Hayes... he'll do it right
05-26-2005, 11:21 AM
Thanks can you pm me his name and number.
Tom
218/287 RWHP/RWTQ
Future
65 MM BBK TB
Cobra R Intake.
Where is Slims?
218/287 RWHP/RWTQ
Future
65 MM BBK TB
Cobra R Intake.
05-26-2005, 11:22 AM
Tom
586-247-0050
Brian Scott...tell him Bubba sent ya
05-26-2005, 11:23 AM
Where is Slims?
10/ Gratiot
05-26-2005, 11:27 AM
586-247-0050
Thanks i appreciate it.
218/287 RWHP/RWTQ
Future
65 MM BBK TB
Cobra R Intake.
05-26-2005, 02:39 PM
#10
586-247-0050
I called Brian and he said that he could only do it to factory specs. His tech doesn't know how to adjust for the bump steer.
218/287 RWHP/RWTQ
Future
65 MM BBK TB
Cobra R Intake.
05-26-2005, 03:21 PM
#11
A friend of mine used to work at 10 & Harper until he was test driving a WS-6 and crashed into a house. Yeah alot of dumbass kids not knowing what they're doing.
05-26-2005, 07:50 PM
#12
Anyone?
Does anyone have a bump steer kit installed?
218/287 RWHP/RWTQ
Future
65 MM BBK TB
Cobra R Intake.
06-01-2005, 10:17 AM
#13
In the 9's
Just have a regular alignment done. The bump steer kit is already supposed to correct a bump steer condition, which will keep the toe alignment constant throughout the range of suspension travel. You don't "align for bump steer" - any alignment shop should be able to check for it though. With the front wheel alignment sensors on, have the alignment guy lift the front end up until the tires come off the turntables, and then pull it down until the suspension bottoms out, and watch for any significant change in toe - there should be little if any with the kit installed.
06-01-2005, 03:37 PM
#14
Thanks for the info, It just said in the directions to have it bump steer aligned, I didn't know exactly what it meant, there are spacers on the bottom and top and it said to have the shop put them where they needed to be. Thanks
218/287 RWHP/RWTQ
Future
65 MM BBK TB
Cobra R Intake.
06-01-2005, 11:33 PM
#15
In the 9's
Actually, I didn't realize that your kit was adjustable. In that case, it should be checked after installation, and adjusted with the shims until bumpsteer has been minimized. It can be checked with some basic tools by yourself, but it involves removing the front springs. You should call Baer and ask them for a baseline shim arrangement, just as a starting point.
