Broad Street Valuations
Unread 07-27-2011, 12:31 PM   #1
Default Quick Tech: Fluid Pump-Integrated ATI SCS-30 Transmission Cooler
In between rounds, the transmission can heat soak because the hot fluid sits stagnant in the case heating all those parts up, much like how the engine temperature will rise after being shut off. The ATI SC-30 cooler pump kicks in when the vehicle turns off. Check out the tech article inside!
ATI Super F Synthetic Transmission Fluid for Drag Racing Automatics NewsBot Dragzine Newsfeed 0 02-15-2011 06:32 PM
PRI 2010:Meziere Enterprises Transmission Overflow Tank & WP329 Pump NewsBot Dragzine Newsfeed 0 12-14-2010 06:40 PM
PRI 2010: Peterson Fluid Systems New R4 WetVac Pump NewsBot Dragzine Newsfeed 0 12-09-2010 08:43 PM
