Unread 07-15-2011, 08:23 PM   #1
Default AFR Releases New High-Flow SBC 245NPP Cylinder Heads
Have you been searching for a high-flow cylinder head that you can bolt onto your car that will help take it from fun to extreme? AFR has something for you! With their new SBC 245NPP heads, you can run common headers and intake manifolds all while pushing 700hp with the right set up.
PRI 2010 ? New LS3/L92 Heads from Trick Flow Specialties NewsBot Dragzine Newsfeed 0 12-10-2010 11:20 AM
Edelbrock?s New RPM Xtreme Big Block Chevy Cylinder Heads NewsBot Dragzine Newsfeed 0 06-03-2010 12:48 PM
Edelbrock?s New RPM Xtreme Big Block Chevy Cylinder Heads NewsBot Dragzine Newsfeed 0 06-03-2010 11:25 AM
Edelbrock RPM Xtreme™ B/b Chevy Cylinder Heads Deliver CNC Perfected Air Flow in a Bo NewsBot Dragzine Newsfeed 0 06-03-2010 10:27 AM
4-valve per cylinder LSx heads from Arao Engineering Joe The Shop 5 04-12-2007 05:39 PM
