Go Back   Detroit Racing Forums > General Discussion > The Gym
Unread 08-24-2007, 08:57 AM   #1
Exclamation Cardio...Dom, get in here.
I know that cardio, to a certain dgree, can, and often does burn muscle while burning fat. But I need to know a few things.
I lift heavy, hard, and intense, and I do ok when it comes to strength.
My cardio has also been pretty intense the past 3 weeks.
No less than 30 minutes total. 10 minutes on the treadmill at a 15 degree incline at 4mph, and then 20 minutes on the stairclimber, set at level 10.
I don't always monitor my heart rate while on the treadmill, (when I do it's at somewhere between 130-150) but I do when on the stairclimber. When on the stairclimber I keep my heart at 150-170...for the entire 20 minutes. By the time I am done I am beyong drenched in sweat.
Then I hit my full workout which is usually at LEAST a full hour worth of very intense heavy lifting.
I need to drop a lot of fat (as far as I am concerned)NOW, but am I doing too much?
Unread 08-24-2007, 10:31 AM   #2
LITTLEMAGS
LITTLEMAGS's Avatar
LITTLEMAGS I need rep points!
it actually looks good.....
2004 mach 1..
stroked 4.6 F1a cog
735rwhp/585 tq for now....
LITTLEMAGS is offline   Reply With Quote
Unread 08-24-2007, 10:32 AM   #3
Ok.
Unread 08-24-2007, 11:49 AM   #4
LITTLEMAGS
LITTLEMAGS's Avatar
^^ sorry so short I had a customer. Ok...well anyways...looks pretty good. I think you NEED to back down the intensity though on cardio.
I do cardio in the offseason 30 minutes on treadmill walking at 8degree incline at 2.7mph-3.0mph..
Enough to burn fat but KEEP muscle. TO MUCH cardio burns more muscle than fat.
OK...BUT you want to burn MORE FAT quicker...WELL THEN do this.
I use a "ramping" method. GET on the eliptical machine and do medium level to easy pace..get you heart rate to about 120-125...then SPEED up until you rate reaches 80 percent max HR...hold for 2 minutes at that rate then slow down...when your heart rate gets back to normal (usually 5 minutes)...REPEAT...
I do 5 cycles of this three times a week ( when I want to burn fat quick)and other times on treadmill at listed rate above.
2004 mach 1..
stroked 4.6 F1a cog
So, you want to start working out and changing your physique... Crazzy_Al The Gym 25 08-17-2007 08:25 AM
1st cardio session in almost a month, this morning... Crazzy_Al The Gym 3 04-10-2007 01:26 PM
"Operation: Narcissism" in full effect...how about you guys? Crazzy_Al The Alley 31 05-22-2006 02:23 AM
