Unread 02-18-2005, 10:24 AM   #1
Default Aluminum or Cast Iron-Which is Better
I'm debating on what type of heads to get for my motor. I know aluminum is lighter and they dissapate heat better. The heads will be going on a 13.5:1 357w in a 82 Mustang w/ a c4 and 4,000 stall cinverter. I'll be running 3:73 or 4:10 for rear gears and a 28x9 or 28x10 slick. Any help will be appreciated!
Unread 02-18-2005, 10:54 AM   #2
You can run a higher CR with aluminum heads, but iron retains heat int he combustion chamber. There are pro's and con's to both, its just a matter of price and personal preference.
Myself, i'd spend the $ on a better iron head. You'll get more bang for the buck.
Unread 02-18-2005, 02:21 PM   #3
All things being equal, a iron head will make more power, because of the heat retention factor.
That being said, aluminum can be repaired far easier than cast iron, should damage occur, and more designs are available in aluminum than iron because of the ease of the modern casting process. Aluminum is also far easier to port(softer), therefore less costly.
The advantage of less weight is a big deal too. On my Olds motor, I shaved over 120#'s off the front end by going with aluminum heads and intake. Thats a decrease in ET right there, without considering the HP increase. I you are switching from iron to aluminum, consider a thinner head gasket, or a smaller combustion chamber, to raise you comp. ratio 1/2 to 1 point, or a max of 11 to 1 for pump gas. This will make up for the power loss from the heat disapation of the aluminum.
Unread 02-18-2005, 02:30 PM   #4
You know too much about this shit!
Unread 02-18-2005, 02:57 PM   #5
Any way you want to look at it, knowledge is power.
Unread 02-18-2005, 03:38 PM   #6
Default Heads
Came across a killer deal on windsor seniors ported for $600 complete ready to go. Now I just gotta raise the cash!! I think I'll go w/ the irons(can't beat the price)!! Thanks for the info guys. Maybe the car WILL be out late this year(it's a big maybe)!
Unread 02-18-2005, 03:43 PM   #7
Swifster
Who, ME?
Swifster's Avatar
Swifster I need rep points!
There's a reason why they don't make aluminum frying pans...
Just another day in paradise!
1964 Studebaker Daytona - 289 Garbage I know I talk soo much shit about how sweet it is going to be...but I know it will never really be done.
Swifster is offline   Reply With Quote
Unread 02-18-2005, 03:48 PM   #8
Actually, they do make aluminum frying pans...lots of them.
Unread 02-18-2005, 04:49 PM   #9
Yeah I'd rather do it right the first time(or in this case the 3d or 4th)!!
Unread 02-18-2005, 05:15 PM   #10
Price always ends up being a major factor, seems like youve found a great deal, I'd go that direction for that price too. Seniors are good heads to start with.
Unread 02-18-2005, 08:17 PM   #11
Default Heads
Yeah gonna go with these once I raise some $$$!!
Unread 02-20-2005, 01:36 PM   #12
unwritten
Always working
unwritten I need rep points!
basically cast iron is stronger, aluminum is lighter....
unwritten is offline   Reply With Quote
Unread 02-20-2005, 09:29 PM   #13
Default Heads
Just gotta sell some parts and I'm in business!!!
