Unread 02-15-2005, 06:03 PM   #1
Default Machine shops (block Work)
long story short...matt took his car to lidio today..he tuned it and got it to run alot better but also said that is motor is worn out and tired..SOOO me and him are going to be doing a stock rebuild on it for now.
probably going to go with the sealed power hyperutectic kit. $269 includes all bearings,gaskits, new pistions(hyperutectic) and oil pump.. thinking about maybe going .030 over just to make sure the block is cleaned up nicely and also so we dont have to ridge ream it.
what are your guys favorite shops that are reasonably priced. the only shop i have personally ever delt with is Booth Arons and they are a bit expensive but do really good work.
what do you guys recommend doing? Remeber BUDGET!! later on he's going to go completely through his motor including forged internals, heads, intake, cam. He just wants the car to run decent for now instead of getting beat by my V6 Grand Am
Sorry for the Novel
Thanks for the help!
Unread 02-15-2005, 06:22 PM   #2
IDJ on Groesbeck and 696.
Unread 02-15-2005, 06:24 PM   #3
At least put forged pistons in it. I take it we're talking 5.0. What year. Tear it apart first, it might just need rings and bearings. I can set you up with a shop that can take care of you. No torque plates, but you're going budget. I us this guy for every thing except full out race motors, and thats only because he doesnt have the torque plates. Did my buddys 5.0 a couple of years ago, and it was only $300 for hot tank, .010 crank and bearings, new cam bearings, freeze plugs, rings, oil pump and gasket set. Over bore is only $10 a hole plus pistons. Can also rebuild rods with arp hardware if you want. A stocker 5.0 rebuild will hold a lot of power as long as you use the forged pistons. I blew the snot out of my old stocker(175hp) and never damaged anything, infact thats the motor I did for my buddy.
PM me if this sounds good.
Unread 02-15-2005, 06:48 PM   #4
PM sent
Unread 02-17-2005, 06:30 PM   #5
silverknight
SLO = Shitty Low Output
silverknight's Avatar
silverknight I need rep points!
couldnt u guys use the 351??
Silver 95 Ford Taurus SE - 104k - modded
White 93 Ford Taurus SHO ATX - 108k - kinda stock
Blue 62 Caddy Sedan De'Ville - FOR SALE $2000firm
silverknight is offline   Reply With Quote
Unread 02-17-2005, 11:22 PM   #6
the one he has is a 351M meaning big block...not exactly a bolt in..
Unread 02-18-2005, 12:44 AM   #7
SHOTyme
Crash
SHOTyme's Avatar
SHOTyme I need rep points!
who needs a fire wall when you can have big block POWA!!!
1994 Buick Regal AKA-The Grannymobile
91 Taurus SHO - currently being parted out and send to the crusher
SHOTyme is offline   Reply With Quote
Unread 02-18-2005, 08:06 AM   #8
Swifster
Who, ME?
Swifster's Avatar
Swifster I need rep points!
Ditto! And for a stock rebuild, I wouldn't bore out the cylinders any more than he has to. If he measures his bores and checks the amount of taper, I think he'll find he could most likely get away with over boring block only .010 or .020. This leaves plenty of room for any further rebuilds necessary or planned in the future.
Just another day in paradise!
1964 Studebaker Daytona - 289 Garbage I know I talk soo much shit about how sweet it is going to be...but I know it will never really be done.
Swifster is offline   Reply With Quote
Unread 02-18-2005, 08:49 AM   #9
yeah we dont plan on any boring or grinding on anything. going to polish the crank and grind it only if its neccesary. the block is just getting ridge reamed and re honed...should cost to much money at all really..
me and greg are trying to get him to do heads,cam,intake forged internals...the works but he's not going for it.. its so much fun spending other people's money...
Unread 02-18-2005, 10:11 AM   #10
Racingqtrsstang
Racingqtrsstang's Avatar
Racingqtrsstang I need rep points!
I would be more than happy to go for it except i dont have that much cash to spare
Racingqtrsstang is offline   Reply With Quote
Unread 02-18-2005, 10:20 AM   #11
Default Motor
What size motor you working on? Just curious.
Unread 02-18-2005, 01:06 PM   #12
