Unread 11-08-2005, 02:44 PM   #1
nitrous_bob
nitrous_bob's Avatar
nitrous_bob I need rep points!
Default nitrous jetting "dry" kits only
here are some jet configs for a lot of different jettings.
the nos 5115 , zex, and edelbrock for sure , i'm quite positive all dry kits use these same jets
NOS Dry kit jetting:
Nozzle---tee---HP
#42 #67 =75
#47 #53 =100
#52 #62 =125
#67 #42 =150
#73 #42 =175
remember 125 and up requires you to shim the nitrous reg.....
'93 Calypso Notch , under construction...
6th stang and counting
nitrous_bob is offline   Reply With Quote
Unread 12-14-2005, 05:39 PM   #2
streetbad
streetbad I need rep points!
How is this done???
streetbad is offline   Reply With Quote
Unread 01-19-2006, 09:36 AM   #3
nitrous_bob
sorry for the late reply....
pop the nitrous reg apart and it goes under the spring.
you can just use a washer...it needs to be .040" thickness, the actual part number from NOS is # 17933-snos
Unread 01-20-2006, 01:09 PM   #4
How about for the 'wet' kit set-ups? (Cheater,etc)
Unread 01-22-2006, 11:55 PM   #5
yes how about those as i will be installing one before summer
Unread 09-27-2006, 11:59 AM   #6
last5liter
last5liter I need rep points!
Nozzle---tee---HP
#42 #67 =75
#47 #53 =100
#52 #62 =125
#67 #42 =150
#73 #42 =175
How does this compensate for different size injectors? (I.E. #19, #24, #30)
Unless this chart is assuming your using stock size #19 iinjectors.
last5liter is offline   Reply With Quote
Unread 10-08-2006, 04:07 PM   #7
speedy
Carnage 06 tour member
speedy's Avatar
speedy I need rep points!
You can go to NOS http://www.holley.com/division/NOS.asp#75 site and get all the instruction for all there kits. There PDF files. Here is the jetting for a cheater.
63/71 = 150hp
73/82 = 180hp
82/91 = 210hp
93/102 = 250
heres the complete instructions for the cheater system
http://www.holley.com/data/Products/...A5051-SNOS.pdf
Mike
http://AHSA.cc
86 Grand National 45,800 miles (For Sale)
86 Mustang GT w/
speedy is offline   Reply With Quote
Unread 10-11-2006, 11:06 PM   #8
63/71 = 150hp
73/82 = 180hp
82/91 = 210hp
93/102 = 250
Cool thanks!
Unread 03-29-2010, 09:28 PM   #9
nitrousmaster
nitrousmaster I need rep points!
Will it be the same jets for the 30 injectors??
nitrousmaster is offline   Reply With Quote
Unread 03-30-2010, 09:34 AM   #10
red347lx
red347lx's Avatar
red347lx I need rep points!
Arent you the "nitrousmaster"? j/k
red347lx is offline   Reply With Quote
Unread 03-30-2010, 10:31 AM   #11
nitrousmaster
nothing else to do???
Curiousity on Nitrous 99SVTAddict The Alley 21 07-29-2005 04:55 PM
