Go Back   Detroit Racing Forums > RSS NewsFeeds > The Car Connection
Unread 11-04-2024, 10:40 AM   #1
Default Ram recalling 33,777 pickups due to stability control issue
Stellantis is recalling certain 2025 Ram 1500 pickup trucks because they may have damaged components that could disable stability control, which is a key safety system that helps prevent skidding and spinning. Without it, drivers can lose control of vehicles more easily. The recall includes 33,777 pickups, although Stellantis told the NHTSA that...
Ram recalls 1.2 million pickup trucks for stability control fail NewsBot The Car Connection 0 09-10-2024 10:59 AM
Ram recalling nearly 85,000 new heavy-duty pickups for fire risk NewsBot The Car Connection 0 02-10-2020 12:37 PM
Ford Recalling Escape For Corrosion, Newer Models For Seat Issue NewsBot The Car Connection 0 04-07-2014 03:35 PM
2013 Ram 1500 Recalled For Stability Control Software Glitch NewsBot The Car Connection 0 07-17-2013 11:49 AM
Honda Fit Recall Affects Stability Control NewsBot The Car Connection 0 04-29-2013 09:43 AM
