01-01-2007, 02:55 PM
Just spent an hour trying to start the truck
And it's a no go. This always happens when it's cold and wet outside... what's most likely problem and how many $100 is it gonna cost to fix?
01-01-2007, 03:17 PM
what kinda truck?? what year?? distributor cap??
I could run 9's....
01-01-2007, 03:39 PM
It's a 97 GM with the 4.3 V6
01-02-2007, 08:46 AM
Thats the problem, its a GM
01-02-2007, 09:40 AM
Hmmm its a Vortec 4.3, correct? It may be the cam sensor. Is the check engine light on?
01-02-2007, 09:53 AM
Run it out of/low on gas recently? Check the dizzy cap... I've seen em crack before as well because of super cold weather if they're old.
"Liter is french, for give me some fucking cola before I break your fucking lip!"
01-02-2007, 11:51 AM
You know, that light is on, I kinda stopped noticing after a couple years.... Last time I checked it, it was related to my exhaust mishap, so I kinda forgot about it... who knows what other codes it's thrown since then.. going to buy one of those code reader things for it today.
01-03-2007, 10:12 AM
Jus take it to a local parts place. Most of them will read them for free.
01-03-2007, 05:15 PM
I know AutoZone will.
01-03-2007, 10:43 PM
#10
SLO = Shitty Low Output
go to murray's, u can rent an obdII tool for free. but u have to put a $160 deposit down, u get it back when u return it.
my neighbor has the same issues. maybe try some wire dry?
Silver 95 Ford Taurus SE - 104k - modded
White 93 Ford Taurus SHO ATX - 108k - kinda stock
Blue 62 Caddy Sedan De'Ville - FOR SALE $2000firm
01-09-2007, 01:36 PM
#11
Ok, so the catalytic converter is plugged and broken inside... $800 GM parts, $500 3rd party... I'm thinking of opting for the cheapest option, just remove them... shouldn't be an issue with that, right? I mean, the stang runs better without them, so the truck shouldnt run worse at least?
01-09-2007, 03:08 PM
#12
! cat
Might need an o2 sim on that though or get it programmed out.
01-09-2007, 03:09 PM
#13
! cat
I've had that SES light on for 3 years, it can stay on if it means I don't have to spend any $$... I'll just check the codes every now and then...
01-09-2007, 03:12 PM
#14
Pull the bulb if it irritates you
01-09-2007, 03:13 PM
#15
No no, it doesn't irritate me at all.. it's rather like an old friend.. I'd think something was wrong if that light wasn't on...
