Unread 11-01-2006, 12:36 AM   #1
11secCobra
94 Cobra 347 stroked 11.9
11secCobra I need rep points!
Default Please Help!
Hey guys I was wondering if anyone had any tips on how to tune a 306 for a trick flow intake? Its fine once your driving but it has kinda a ruff idle (besides the cam)..
I was wondering if someone could help or tell me where I can find a diagram that tells me info on it...
Thanks
11secCobra is offline   Reply With Quote
Unread 11-01-2006, 05:20 AM   #2
Check for a vacuum leak. Just swapping intakes shouldn't have any effect on idle quality unless you changed MAF and injectors at the same time. In that case its going to need the ecm re-tuned.
Unread 11-01-2006, 01:54 PM   #3
nick
nick I need rep points!
like bubba said sounds like a leak, were the surfaces that the intake bolted onto clean and flat? maybe its sitting on there crooked or something or you didnt plug something back in. Is it surging or just rough?
nick is offline   Reply With Quote
Unread 11-01-2006, 11:15 PM   #4
11secCobra
Thanks guys I really appreciate it..
We found two vaccum leaks and plugged them but its still running a little ruff.. I also forgot to mention we put 24# injectors in it too!
So anything at this point helps, Also my fuel pressure is only at 40 should it be higher than that?
Unread 11-02-2006, 08:39 AM   #5
Boomer!
Infraction Jackson !!!!!!
Boomer!'s Avatar
Boomer! I need rep points!
Did you tune it or change the sample tube in the MAF for the injectors?
Boomer! is offline   Reply With Quote
