i know what you mean about pools but, i bought acouple of items to try and make if easy as i cold.
65 Polaris Cleaner
The Polaris 65 is designed to operate in Aboveground Pools with even the lowest energy output filter systems. Powerful; jets loosen debris from around the ladder and pool walls. The Polaris 65 collects debris in it's own bag and sweeps any aboveground pool in less than 3 hours.
The Polaris 65 comes with a 3 year frame warranty and a 1 year warranty on the rest of the parts.
just a quick twist in the water return and does great job.
Intermatic Heavy Duty Outdoor Timer w/ Twist Lock Plug and Receptacle Enjoy automated convenience for you swimming
pool by installing an automatic
timer for your filter system.
Rating:
No user ratings [
rate this item]
+ Add to Shopping List |
See More Like This
this has the twist lock runs about 50.00
FROG MINERAL SYSTEMS
POOL FROGŪ for Above Ground Pools
With
POOL FROGŪ Mineral Systems, taking care of your pool water has never been easier. Minerals help control bacteria and keep the pH neutral so you can reduce chlorine use up to 50% (Compared to minimum EPA recommended chlorine level of 1.0 ppm for a stabilized swimming pool). With minerals you can reduce the irritations associated with chlorine such as, red stinging eyes, dry itchy skin and faded swimsuits while enjoying crystal clear, soft water for greater swimming enjoyment.
This system includes the POOL FROGŪ Cycler with a precise metering dial and Mineral Reservoir. Pool Frog Chlorine Bac Pacs sold separately. Available for Above Ground pools up to 25,000 gallons, the Mineral Reservoir will last 6 months, and the Chlorine Bac Pacs last 2-3 weeks depending on weather and bather load. The new and improved Pool Frog has a more precise control dial, easier cap removal and cool new look
have had 0 problems with this systemsince i installed it.
