Unread 04-06-2005, 09:21 AM   #16
Originally Posted by Deuce450
So the use of Nitrous changes this general rule? If this is the case then why not run 3.90's? On the streetable side I just don't want to be turning 4,000rpm going down the freeway. I generally drive between 70-80mph. This is not my daily driver but I do like to drive the stang to work (40 miles one way) and just take it for a spin when ever I can. Thanks for all the info. this site is the BEST.
Scott, I'll call you today to set up a time.
My C4 w/ 3.73's turns about 4000 at 75... i wouldn't think you'd have a problem with 4.10's and aod, but even if you do you could always get a taller tire like i did to make up for it a little...
Unread 04-06-2005, 12:44 PM   #17
hopefully someone can help me out with this..
a trans without over drive like a th350 or c4 whatever..final drive is 1:1 correct? well if at 75 mph ur runnin 4000 rpm w/ 3:73's. so at the track when people are makin passes @ 110+ what rpm are they spinning, especially since alot of them run 4:10's or larger?? i dont like taking my motor passed 6k. so is this gonna limit me at the strip so my mph wont be as high??
Unread 04-06-2005, 01:06 PM   #18
Racingqtrsstang
Racingqtrsstang's Avatar
Racingqtrsstang I need rep points!
I've got 373's in my car and it's a good all around gear. I thought about 390's also but when i called around there were 1. much more expensive or 2. weren't in stock and didnt know when they could get them in stock. HO that was over a year ago But i'd say 373
Racingqtrsstang is offline   Reply With Quote
Unread 04-06-2005, 04:07 PM   #19
2L8IWIN
the slowest
2L8IWIN's Avatar
2L8IWIN I need rep points!
i have 3.73s and with a 75 shot 26inch tire and drag shocks i think it was like 1.8 60ft not to bad for an AOD
2L8IWIN is offline   Reply With Quote
