02-11-2010, 01:33 PM
#16
Sold a few more items. Make offers.
http://photobucket.com/6PKRTSE1 for photo's of the new items.
Ford:
-New- (2) sets ARP BBF Head Bolt Kits p/n 253-3701 $ 100.00 ea.-SOLD
-New (2) sets ARP S.S. BBF intake bolt kits p/n 455-2001 $ 30.00 ea.-SOLD
-New (7) sets 351C main Brg sets p/n 1463 $ 40.00/set
-New (1) pr. T&D BBF 429-460 rocker arms p/n 14-128S w/stands & hdwe used for mock up only $ 40.00/pr.
-New (5) sets ARP 2.0L Zetec 9MM Ford rod bolt kits p/n 151-6005 $25.00 ea.
-New (2) ea. Wilson Manifolds TPS p/n 481003 $ 35.00 ea.-SOLD
-New (1) pr 351 Ford header gaskets p/n 2502 $ 15.00/pr
-New (1) ea. MSD big cap rotor p/n 8484 $ 10.00 ea.
-Used (1) right side ony 83 Mustang GT spolier corner pc. $ 10.00
Chevy:
-New 2.02 x 7 x 5.010 rad. grve s.s. int valves p/n F2206PQ $ 100.00/set
Mopar:
Most brand new NOS in packages or slightly used (Dyno time only)
-5.7L Hemi fuel injection set ups(5)with throttle bodies, injectors, injector rails, spark plug wire assy's etc $250.00 ea. , Aircleaner box assy (6) $40.00 ea. , Flwheels (7) with hdwe $40.00 ea. , Bellhousings (2) $100.00 ea.(SOLD), Complete engine bay wire harnesses (2) $100.00 ea. , idle pulley (5) 15.00 ea., tensioner pulley (5) $15.00 , Exhaust manifolds heat shields (6) $5.00 ea. Emissions tubes $5.00 ea. (2) many bags,boxes of NOS mounting hdwe, clips & fasteners etc.
-76' 400 block & crank $350.00 obo-SOLD
Misc Race:
-New (4) ARP axle studs kits p/n 100-7706 $ 25.00 ea.
-New (2) FAST 0-100 psi pressure sensors p/n 307062 $ 100.00 ea.-SOLD
-New (1) Canton Racing 1" phoenolic carb spacer 4150 $ 45.00 ea.-SOLD
-New (1) Holley 1/4 spacer/gasket & studs kit 4150 p/n 108-12 $ 10.00 ea.
-New (1) set Speed Pro rings p/n R9771 +5 $50.00 / set
-New (1) 2" fan spacer & bolt kit $ 10.00 ea.
-New (1) CSR push/pull shiter cable p/n CSR6002 $ 40.00 ea.
-New (1) lot misc titanium 10 degree keeper & retainers $ 150.00 obo for all 5 bags
-New (1) Weaver Bros 5 stage dry sump pump $ 850.00
-New (1) Flex-a-lite electric fan t-stat controller $ 10.00-SOLD
-New (1) 2 place NOS 110V electric/water bottle heater $ 175.00-SOLD
-Used (1) NOS Powershot Kit with NOS purge kit, micro switch & push button, fuel pressure shut off switch & blue NOS 10 lb bottle $ 275.00 obo
-Used (1) NX fuel Injected Wet nitous kit with 75-350 jets, new RPM activation controller (p/n 18959) NX 10 lb bottle $300.00 obo
-Used (1) NOS 2-1/2 turbo lntercooler spray kit w/ compucar solenoid & nozzle. $ 125.00
-Used (1) NOS bottle valve $4.00 obo
-used (1) pr 28 x 10.5 x 15W M/T E.T Drag slicks $200.00 obo
-used (1) pr 31.25 x 12.25 x 15W E.T. Drag slicks $250.00 obo
-used (2) twin turbo set up off of V-6 Ford. IHI turbos Serial # FHB5. $ 250.00 ea. Obo
-used (2) Alumi-star 2.0 centers, polished rears 4-1/2” bolt pattern. $150.00/ pr.
call 1-313-505-7948 Make an offer on all items. I have no use for any of the items & need to make room.
02-11-2010, 01:34 PM
#17
$150.00, Come & get them if you can use them.
02-11-2010, 01:35 PM
#18
Can you send me a pic of the tires?
02-11-2010, 01:36 PM
#19
I can come get them now.
02-11-2010, 01:41 PM
#20
Sorry, I don't have any pics of them currently. They have alot of life left on them. I Had over 20 sets at one time. Everyone that comes over to look at a pair takes at least one pair with them.
I won't be at home until after 4:30 sometime. Any time after that will be fine.
02-11-2010, 01:51 PM
#21
pm sent
