Register FAQ/Rules Image Hosting Members List Calendar Forum Home Mark Forums Read
Unread 12-04-2006, 05:39 PM   #1
Default 95 Chevy Silverado
I'm wanting to do an electric cooling fan and do away with the stock belt driven clutch fan.
Any recommendations? I need something with a thermostat that turns it on automatically. No ghetto "wire it to a switch" bs.
Thanks
Unread 12-04-2006, 09:33 PM   #2
Plenty of guys on www.fullsizechevy.com have done that mod. Take a look at the forums there
Unread 12-22-2006, 01:13 AM   #3
MCM
In the 9's
MCM's Avatar
MCM I need rep points!
You need to get a thermostatic switch like this one: http://store.summitracing.com/partde...5&autoview=sku and wire it in to a relay to control the power to the fan itself. Ignition "switched" power should be used for the "hot" side so your fan doesn't run your battery down after you shut your engine off. This should have it's own seperate fuse also, based on the amperage requirement of your fan (5 to 10 amps higher than the fans actual rating to compensate for amperae surge at motor start up). Use appropriately gauged wire to handle this load also.
MCM is offline   Reply With Quote
Thread Tools
Display Modes
chevy 305 silverknight Classifieds 2 09-13-2006 10:40 PM
2006 Super Chevy @ Milan Joe Events 2 09-11-2006 06:43 PM
2000 Chevy S-10 for sale DeJay Classifieds 0 11-18-2005 12:10 PM
chevy mods 69harleysport The Shop 6 10-29-2005 04:05 PM
1972 Chevy C10 body SLAMMED rzyzzy Classifieds 4 07-05-2005 05:53 PM
